Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » TENEO: StoreResource.LOAD_STRATEGY_PARAM
TENEO: StoreResource.LOAD_STRATEGY_PARAM [message #76385] |
Fri, 23 March 2007 14:54 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: christian.donhofer.net
hi all!
i need to configure teneo to load all references of a loaded object into
a resource.
on the elver website
( http://www.elver.org/hibernate/hibernateresources.html#Load+ of+referenced+Objects),
it is said that i need to set the StoreResource.LOAD_STRATEGY_PARAM to
StoreResource.ADD_TO_CONTENTS.
unfortunately, i can find neither of these constants in the
org.eclipse.emf.teneo.resource.StoreResource class.
where do i find them? since many variable names etc. on the elver website
are out of date, i believe they might have been moved&renamed. quick
answers would be very appreciated =)
TIA, cheers, chris
Re: TENEO: StoreResource.LOAD_STRATEGY_PARAM [message #76402 is a reply to message #76385] |
Fri, 23 March 2007 15:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Martin Taal![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mtaal%40springsite.com) Messages: 5468 Registered: July 2009 |
Hi Christian,
In the version I have all these constants are present (in the StoreResource class). Which version of
Teneo are you using?
The variable names on the website should be all valid for the 0.8.0 release with many also being
valid for the 0.7.5 release.
gr. Martin
Christian Donhofer wrote:
> hi all!
> a resource.
> TIA, cheers, chris
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: TENEO: StoreResource.LOAD_STRATEGY_PARAM [message #76416 is a reply to message #76402] |
Fri, 23 March 2007 15:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
hi martin!
thx for the quick answer! nice to see someone being so motivated and
supportive =)
at the moment im using 0.7.5, so i'll try and use 0.8.0 now.
cheers, chris
On Fri, 23 Mar 2007 16:00:53 +0100 wrote Martin Taal:
> Hi Christian,
> gr. Martin
Re: TENEO: StoreResource.LOAD_STRATEGY_PARAM [message #76448 is a reply to message #76431] |
Fri, 23 March 2007 15:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
hmmm, somehow i cant find them in 0.7.5, but i just upgraded to 0.8.0 and
everything works fine now!
cheers, chris
On Fri, 23 Mar 2007 16:15:33 +0100 wrote Martin Taal:
> These constants should also be in 0.7.5.
> The 0.8.0 release requires emf 2.3 (and eclipse 3.3/jdk 1.5).
> gr. Martin
>> hi martin!
>> supportive =)
>> cheers, chris
>>> Hi Christian,
>>> gr. Martin
Re: TENEO: StoreResource.LOAD_STRATEGY_PARAM [message #76463 is a reply to message #76448] |
Fri, 23 March 2007 16:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
hi again!
accessing the constants now works, which leads to the following query:
hibernate://?dsname=AuthortoolDataStore&loadStrategy=add ToContents&query1=from
ModuleFolder where id='modfo-27C47B58-71F7-6F08-DDCE-E40D4EBA305C'
still, the "lazily linked" objects are not being loaded into a resource.
instead, the serialized string contains an empty tag with a href:
<lobj:learningUnit> hibernate://?dsname=AuthortoolDataStore&loadStrategy=add ToContents&query1=from
ModuleFolder where
id='modfo-27C47B58-71F7-6F08-DDCE-E40D4EBA305C'#learn-1C3917 34-EF05-CABA-2E9E-7933863BCE4B </lobj:learningUnit>
here's the code im using:
session = getSession();
Transaction tx = session.getTransaction();
ResourceSet resourceSet = getResourceSet();
Resource rs = resourceSet.createResource(URI.createFileURI("soEinDummy.lobj "));
// create an uri using the SessionController name
URI uri1 = URI.createURI("hibernate://?dsname=" + dataStore.getName() + "&" +
StoreResource.LOAD_STRATEGY_PARAM + "=" + StoreResource.ADD_TO_CONTENTS +
"&query1=from "+eclassname+" where id='"+id+"'");
System.out.println("Loading with this QUERY: "+uri1.toString());
final Resource res1 = resourceSet.createResource(uri1);
tx.begin();
// now load the resources
try {
res1.load(Collections.EMPTY_MAP);
} catch (IOException e1) {
// TODO Auto-generated catch block
e1.printStackTrace();
tx.commit();
System.out.println("LOADED RESOURCE CONTAINS "+res1.getContents().size()+"OBJECTS!");
System.out.println("LOADED RESOURCESET CONTAINS "+res1.getResourceSet().getResources().size()+" RESOURCES!");
for(Iterator iter = res1.getResourceSet().getResources().iterator(); iter.hasNext();){
Resource resource = (Resource)iter.next();
if(resource.getContents().size() > 0){
EObject eo = EcoreUtil.copy((EObject)resource.getContents().get(0));
rs.getContents().add(eo);
after that, all needed objects should be in rs, shouldn't they?
TIA, chris
p.s.:
i also tried:
for (Iterator iter = res1.getContents().iterator(); iter.hasNext();) {
EObject element = (EObject) iter.next();
System.out.println("adding "+element.toString());
EObject eo = EcoreUtil.copy(element);
System.out.println("resource contains:" +eo.toString());
but that throws a ConcurrentModificationException.
Re: TENEO: StoreResource.LOAD_STRATEGY_PARAM [message #76480 is a reply to message #76463] |
Fri, 23 March 2007 16:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Yes I would say that the copy action should load all the objects, can you debug through the copy
action and see if it traverses the containment tree?
A teneo resource has a special iterator which does not load unloaded lists but I do not think that
the copy action makes use of that.
gr. Martin
> hi again!
> ModuleFolder where
> tx.begin();
> try {
> tx.commit();
> TIA, chris
> p.s.:
> i also tried:
The Netherlands
Re: TENEO: StoreResource.LOAD_STRATEGY_PARAM [message #76561 is a reply to message #76480] |
Fri, 23 March 2007 17:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
the copy function seems to use
HibernateResource(StoreResource).getContents() line: 455
without this method, f.i. using
EObject eo =
(EObject)resource.getContents().get(0);
i get a dangling href exception anyway.
but the problem seems to be that the loaded resource doesn't contain
anything else but the contained objects of the requested one.
cheers, chris
On Fri, 23 Mar 2007 17:35:32 +0100 wrote Martin Taal:
> gr. Martin
Re: TENEO: StoreResource.LOAD_STRATEGY_PARAM [message #77675 is a reply to message #76625] |
Fri, 30 March 2007 15:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Christian,
Okay it runs. Your original call was:
ModuleFolder where
What the copy action does is copy the containment structure, so if an eobject is copied then only
its contained children are copied. All non-containment relations still point to objects from the
original tree (which is in a different resource). When you then serialize the new resource these
pointers to the 'original db' resource are serialized to a href as you can see. As far as I can see
it works correctly.
Here is the output I get:
<lobj:ModuleFolder xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:lobj="lobj.ecore"
id="modfo-27C47B58-71F7-6F08-DDCE-E40D4EBA305C" timestamp="2007-03-21T12:22:20.000+0100">
<lobj:folderMeta id="folme-B9B50DAC-4C93-6C2C-906C-27CC08836C32"
<title>- kein Titel -</title>
</lobj:folderMeta>
<lobj:moduleFolder id="modfo-252FEE5B-DD17-8AAA-95EC-2F183B681088"
timestamp="2007-03-21T12:22:22.000+0100">
<lobj:folderMeta id="folme-2D60FC6B-255D-6757-1AAE-443557D3C043"
timestamp="2007-03-21T12:22:29.000+0100">
</lobj:folderMeta>
<lobj:module id="modul-B3682DBC-4214-5079-5AFA-D1442772E611"
<lobj:moduleMeta id="modme-1746A529-4DD0-0712-B3FA-EEA5FA1D6BFD"
timestamp="2007-03-21T12:22:31.000+0100">
<lobj:didacMeta id="didme-29DD1E0D-F4D9-A4C9-9FB8-CB1BB8716B39">
<lobj:language> hibernate://?dsname=AuthortoolDataStore&loadStrategy=add ToContents&query1=from
ModuleFolder where id='modfo-27C47B58-71F7-6F08-DDCE-E40D4EBA305C'#de</lobj:language >
</lobj:didacMeta>
<creationDate>2007-03-21T12:22:31.000+0100</creationDate>
</lobj:moduleMeta>
<lobj:rootNode xsi:type="lobj:ThemeNode" id="theno-E6ECA384-CBC8-05D5-45EE-EF7D4B439932">
<lobj:childnodes xsi:type="lobj:ThemeNode" id="theno-3919AAAF-2CB9-AFB2-12EB-59F114262B4D">
<lobj:theme id="theme-8F5F78E5-80A2-C5E6-549A-A74EA345B6AF"
timestamp="2007-03-21T12:22:33.000+0100">
<lobj:simpleDidacMeta id="simme-A35AC636-3DB6-5817-90D4-B46843E5136E">
</lobj:simpleDidacMeta>
</lobj:theme>
<lobj:childnodes xsi:type="lobj:LuNode" id="lunod-927DAFBB-EBBC-864D-7C29-9CA78A9699B5">
ModuleFolder where
</lobj:childnodes>
<lobj:childnodes xsi:type="lobj:LuNode" id="lunod-0900BE6A-D0B1-B88C-0B8C-83C07C34261A">
ModuleFolder where
id='modfo-27C47B58-71F7-6F08-DDCE-E40D4EBA305C'#learn-DCDF4C 0A-088A-F507-E839-DC264DF1A66B </lobj:learningUnit>
</lobj:childnodes>
</lobj:childnodes>
</lobj:rootNode>
</lobj:module>
</lobj:moduleFolder>
</lobj:ModuleFolder>
> hi!
> here's the file:
> http://donhofer.net/mirror/hibernate/lobj.ecore
> TIA, chris
> On Fri, 23 Mar 2007 19:11:13 +0100 Martin Taal wrote:
>> Hi Christian,
>> Can you send me the ecore? You posted the test program so I can try to reproduce it.
>> gr. Martin
>>> just to add all necessary information:
>>> http://donhofer.net/mirror/hibernate/hibernate.hbm.xml
>>> im loading a modulefolder.
>>> missing in the loaded resource(&set): LearningUnit (and contained)
>>> (strangely) present in the resource: Language
>>> cheers, chris
The Netherlands
Re: TENEO: StoreResource.LOAD_STRATEGY_PARAM [message #603823 is a reply to message #76385] |
Fri, 23 March 2007 15:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Christian,
gr. Martin
> hi all!
> a resource.
> TIA, cheers, chris
The Netherlands
Re: TENEO: StoreResource.LOAD_STRATEGY_PARAM [message #603833 is a reply to message #76463] |
Fri, 23 March 2007 16:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
gr. Martin
> hi again!
> ModuleFolder where
> tx.begin();
> try {
> tx.commit();
> TIA, chris
> p.s.:
> i also tried:
The Netherlands
Re: TENEO: StoreResource.LOAD_STRATEGY_PARAM [message #604078 is a reply to message #76625] |
Hi Christian,
ModuleFolder where
it works correctly.
</lobj:folderMeta>
</lobj:folderMeta>
</lobj:didacMeta>
</lobj:moduleMeta>
</lobj:theme>
ModuleFolder where
</lobj:childnodes>
ModuleFolder where
</lobj:childnodes>
</lobj:childnodes>
</lobj:rootNode>
</lobj:module>
> hi!
> here's the file:
> TIA, chris
>> Hi Christian,
>> gr. Martin
>>> cheers, chris
The Netherlands
Current Time: Tue Jul 16 11:25:08 GMT 2024
Powered by FUDForum. Page generated in 0.05663 seconds
