Comment char improvements [message #644275] |
Fri, 10 December 2010 10:40 |
Marius Cojocaru Messages: 8 Registered: November 2010 |
Junior Member |
I write an editor for a language who has a different comment char then '#'.
The way is implemented now in the dltk core classes, makes difficult to change this.
Example
ScriptSourceViewerConfiguration has a nice method getCommentPrefix, and is easy to override, since anyway every language will define a class that extends this
class ScriptCommentScanner has a deprecated method getCommentChar that is still used, so I have to create a class that extends the ScriptCommentScanner, and override the getCommentChar.
worse class TodoTaskBuildParticipant in findCommentStart use hard coded the # so I have again to override this and copy the exact functionality of the upper class and change the comment char.
Can you please add a single place where the comment char is defined ( maybe TextTools).
[Updated on: Fri, 10 December 2010 11:25] Report message to a moderator
FUDForum. Page generated in 0.04623 seconds
