Re: Bundles in usr and pickup behave differently [message #559608 is a reply to message #559602] |
Fri, 17 September 2010 11:40 |
Hi Guofeng,
This is expected behaviour, the pickup directory is a watched directory for you to deploy your application bundles and artifacts to. The repository/usr directory is also a watched directory but bundles and other artifacts in it will not be hot-deployed, it is for your applications dpendancies.
From your description below, you should place both the commons bundles in the usr directory and, if needed, they will be started when you deploy an application bundle.
More information can be found in the User guide http://www.eclipse.org/virgo/documentation/virgo-documentati on-2.1.0.M04-incubation/docs/virgo-user-guide/html/ch08.html and http://www.eclipse.org/virgo/documentation/virgo-documentati on-2.1.0.M04-incubation/docs/virgo-user-guide/html/ch06.html
Hope this helps,
Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
FUDForum. Page generated in 0.04156 seconds
