ATF installation/building problems on MacOSX [message #523435] |
Fri, 26 March 2010 13:42 |
Jan F. Messages: 7 Registered: March 2010 |
Junior Member |
I am trying to get ATF working on MacOSX but am encountering problems along everything I try.
Here is what I am doing:
Mac OS X Snow Leopard
Eclipse 3.5 Galileo SR2, PDE, 64 bit cocoa version, downloaded from here: http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/galileo/SR2/eclipse-rcp-galileo-SR2 -macosx-cocoa-x86_64.tar.gz
1, the installation path (following http://wiki.eclipse.org/ATF/Installing)
- unzip the Eclipse, choose workspace
- follow the steps in the ATF/Installation page exactly
On trying to run using Run As -> Run in Mozilla, it switches to the Web Browser Tools perspective, but subsequently fails with an error:
Unhandled event loop exception
No more handles [Could not detect registered XULRunner to use]
I looked into the XULRunner plugin, but the JAR seems to be empty.
I tried to download XULRunner separately and install it, but that did not help.
2. the building ATF part (following http://wiki.eclipse.org/ATF/Workspace)
- follow the steps in ATF/Workspace page exactly
Checked out the team set, went to releng and clicked Set as Target Platform in the atf.target file.
This download whole bunch of stuff as expected, but along the way shows this error:
An internal error occurred during: "Resolving Target Definition".
Profile TARGET_DEFINITION:resource:/org.eclipse.atf.releng/pde/atf.t arget is not current.
Ultimately finishes, but an error is still shown in org.eclipse.atf.debug.test:
Bundle 'org.eclipse.wst.common.project.facet.ui' cannot be resolved MANIFEST.MF /org.eclipse.atf.debug.test/META-INF line 12 Plug-in Problem
The project was not built since its build path is incomplete. Cannot find the class file for org.eclipse.core.runtime.CoreException. Fix the build path then try building this project org.eclipse.atf.debug.test Unknown Java Problem
The type org.eclipse.core.runtime.CoreException cannot be resolved. It is indirectly referenced from required .class files ATFProjectHelper.java /org.eclipse.atf.debug.test/src/org/eclipse/atf/debug/testpl ugin line 1 Java Problem
If I try to run the ATF core configuration, I get:
java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Can anybody shed a light on how to get ATF working (ideally through the ATW/Workspace path)?
-Jan
Re: ATF installation/building problems on MacOSX [message #523498 is a reply to message #523435] |
Fri, 26 March 2010 15:25 |
Jacek Pospychala Messages: 159 Registered: July 2009 |
hi Jan,
the problem may be related to the x86_64 platform. If you followed wiki
install steps, you probably installed Mozilla XULRunner from Zend update
site. Unfortunately it's missing 64-bit build for Mac, because Mozilla
provides only 32bit builds.
So you have two alternative options:
1. find x86_64 XULRunner build for Mac and launch Eclipse with extra
params -vmargs
-Dorg.eclipse.swt.browser.XULRunnerPath=/path/to/64bitXulrun ner
2. get Eclipse 32bit build and try standard install there again
Thanks for trying ATF!
Jacek
> here:
> not help.
> shows this error:
> Plug-in Problem
> line 1 Java Problem
> tarter.java:368)
> tarter.java:179)
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> -Jan
FUDForum. Page generated in 0.03697 seconds
