| order of attributes when writing a schema [message #52135] |
Wed, 01 September 2004 20:03  |
Originally posted by: gj.puredge.com
Is there a particular order of element attrinutes when writing out a schema.
For example, an element gets written as:
<xsd:element minOccurs="0" maxOccurs="1" name="NewField" type="xsd:string"/>
If I edit the xsd file and change the order, name first for example, it will
be written in that same order once I load it again and re-save.
Is there a way to control this?
Gary
| Re: order of attributes when writing a schema [message #52163 is a reply to message #52135] |
Thu, 02 September 2004 06:08  |
Gary,
I believe that the underlying DOM typically sorts the attributes
alphabetically and serializes them that way. I've found it annoying
too, but I've seen no way around it. If anyone does, I'd be interested.
>Thanks
>Gary
| Re: order of attributes when writing a schema [message #591277 is a reply to message #52135] |
Gary,
>Thanks
>Gary
FUDForum. Page generated in 1.05423 seconds
