Meta-data [message #30] |
Wed, 08 September 2004 18:15 |
Matt Casters Messages: 2 Registered: July 2009 |
Junior Member |
It was very interesting seeing your proposal on the eclipse.org website and
I would love to participate in the coding!
The thing is, over the course of the last 3-4 years, I have been building an
ETL engine from scratch using java/SWT.
The engine is now at version 2.0 (try it at http://www.kettle.be) is well
tested at several projects and has been a lot of fun to write. Furthermore,
it was a very interesting learning experience for me. If you see something
you would like, let me know. It's a hobby project gone past 100.000 lines
of code.
The idea behind the whole Kettle concept was to describe what the ETL engine
should do in XML. That means it is 100% meta-data based. I guess it's the
same idea that BIRT has.
Concerning this XML description, an important question come to mind. Do you
have a standard in mind for describing the reports? (Layout, Layout/data)
Do you plan to use an existing one like CWMI
http://www.oasis-open.org/cover/omg-cwmi.html (note the last modified
09-MAY-2001 :-)) or XMI http://www.oasis-open.org/cover/xmi.html (Last
modified: May 03, 2002).
Or perhaps this is a chance to come up with something new?
Matt
Re: Meta-data [message #31 is a reply to message #30] |
Fri, 10 September 2004 00:59 |
Wenfeng Li Messages: 25 Registered: July 2009 |
Junior Member |
Hi, Matt
Thanks for your message. We're definitely interested in additional help for
development. Once the project is approved by the Board, we'll follow up with
you to talk about how you can participate in the BIRT project.
As for the report design description format, or report design schema, I
suspect we will not be using CWMI or XMI. We would like to design a new XML
file format that is concise and easy to read by the people who write reports
and design tools that write reports. An XMI based design file format
probably is too verbose for a human being to read. And CWMI is designed for
modeling data warehousing objects, using it to describe report lay out and
presentation properties probably is not a good fit.
Wenfeng
"Matt Casters" <matt.casters@kettle.be> wrote in message
news:chni0c$7p7$1@eclipse.org...
and
an
Furthermore,
something
> of code.
engine
the
you
> Best regards,
> Matt
Re: Meta-data [message #35 is a reply to message #31] |
Tue, 14 September 2004 23:29 |
Please do not invent one more XML format. People will not write reports
with the bare hands, they will write with a tool. Be it cat, vi, emacs,
eclipse plugin...
Create a object model for the report definition, generate a quick EMF
model out of it and be done with the storage and concentrate on your
business value. If you will need a fancy format later, you can replace
the EMF/XMI with it while maintaining the application stack on top.
florin
Re: Meta-data [message #48 is a reply to message #35] |
Wed, 22 September 2004 00:27 |
Originally posted by: red1.red1.org
"Florin Iucha" <fiucha@ugs.com> wrote in message
news:ci7uls$cs8$1@eclipse.org...
> eclipse plugin...
I think what Florin said here should be one of the cardinal sub-rules. May i
extend slightly - I am working on sourceforge.net/projects/compiere-mfgscm
and ppl like us doesnt want to grapple with even the tools, meaning the
tools must be intuitive and taken for granted. I find Eclipse so much that,
just by showing me a few tricks and i m off almost a guru.
Also - In our project (i m just the tutorial writer) the JSP gal and the
Shop Floor guy ( i have no idea what they are doing but they are working
hard, but i wouldnt want to bother them about BIRT just yet), so my worry is
this: "Whatever XML format or tags they deal with i want to finally able to
take those and dump into BIRT easily. Meaning interoperatibility of
standards (Main cardinal rule).
However, (just in case we didn't read WenFeng right) if the new XML humanly
intuitive (non-verbose) form suggested by WenFeng is interoperatable, then
thats just perfect! And very considerate of BIRT too.
FUDForum. Page generated in 0.03967 seconds
