Home » Archived » BPMN Modeler » Look and feel modifications
Look and feel modifications [message #3456] Thu, 06 November 2008 04:50 Go to next message
Hi everybody ,
I'm trying to personnalise the look and feel of my diagram which is based
on data that exists on a DB.
I'm following the sample at :
http://wiki.eclipse.org/STP/BPMN_Component/Developing_with_t he_STP_BPMN_modeler.
I write the following snippet :
private class ActivityEditPartWithBackground extends ActivityEditPart {
ApplicationWindow w;
public ActivityEditPartWithBackground(View view) {
super(view);
protected IFigure createNodeShape() {
// recupération des identifiants des différents objets de notation BPMN
final int ese = ActivityType.EVENT_START_EMPTY;
final int t = ActivityType.TASK;
final int gdbe = ActivityType.GATEWAY_DATA_BASED_EXCLUSIVE;
ActivityFigure figure = new ActivityFigure() {
public void paintFigure(Graphics graphics) {
super.paintFigure(graphics);
//modification goes here
f (getActivityType() == gdbe)
{graphics.setBackgroundColor(Display.getCurrent().getSystemC olor(SWT.COLOR_BLUE));
if (getActivityType() == t) {
graphics.setBackgroundColor(Display.getCurrent().getSystemCo lor(SWT.COLOR_CYAN));
graphics.setForegroundColor(Display.getCurrent().getSystemCo lor(SWT.COLOR_DARK_RED));
if (getActivityType() == ese) {
return primaryShape = figure;
My problem is the changes goes well for the task Acivity but not for the
other types .
How Can I fix this ??
Best Regards ,
Dali.
Re: Look and feel modifications [message #3493 is a reply to message #3456] Thu, 06 November 2008 06:34 Go to previous message
Originally posted by: atoulme.intalio.com
Look at the createNodeFigure method, depending on the activity type,
createNodeShape is not always called. For a gateway or an event, you
will need to override a different class.
Antoine
Previous Topic:French version
Next Topic:Adding new Artifacts
Current Time: Fri Oct 31 06:32:12 EDT 2025
Powered by FUDForum. Page generated in 0.15591 seconds
