IllegalStateException when editing Complete OCL file [message #1863697] |
Wed, 21 February 2024 17:53 |
Guillaume Dupont Messages: 21 Registered: April 2017 |
Junior Member |
I am encountering major issues with Complete OCL, I really do not know what to do. I guess I must be doing something wrong?
I have a fresh installation of Eclipse Modeling 2023-12 (from Oomph) on Java 17, on which I installed OCL 6.19 "All-in-one SDK" from the update site (https://download.eclipse.org/modeling/mdt/ocl/updates/releases/6.19.0). I am on a new empty workspace (no .metadata, no nothing, everything is fresh).
I create a project, I create a .ecore meta-model, so far so good. Then I try to create a Complete OCL document. I get an error dialog about "Cannot modify resource without a transaction". When I close the OCL and I open it again, I get an error view instead of the editor, with the following error and stack trace:
java.lang.IllegalStateException: Cannot modify resource set without a write transaction
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.assertWriting(TransactionChangeRecorder.java:344)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.appendNotification(TransactionChangeRecorder.java:298)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.processObjectNotification(TransactionChangeRecorder.java:280)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.notifyChanged(TransactionChangeRecorder.java:236)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.ocl.pivot.internal.TypedElementImpl.setType(TypedElementImpl.java:184)
at org.eclipse.ocl.pivot.internal.PropertyImpl.unloaded(PropertyImpl.java:1782)
at org.eclipse.ocl.pivot.internal.resource.ASResourceImpl.unloaded(ASResourceImpl.java:568)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.doUnload(ResourceImpl.java:1706)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doUnload(XMLResourceImpl.java:720)
at org.eclipse.ocl.pivot.internal.resource.ASResourceImpl.doUnload(ASResourceImpl.java:332)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.unload(ResourceImpl.java:1721)
at org.eclipse.ocl.pivot.internal.ecore.es2as.AbstractExternal2AS.dispose(AbstractExternal2AS.java:77)
at org.eclipse.ocl.pivot.internal.manager.PivotMetamodelManager.dispose(PivotMetamodelManager.java:697)
at org.eclipse.ocl.pivot.utilities.AbstractEnvironmentFactory.disposeInternal(AbstractEnvironmentFactory.java:677)
at org.eclipse.ocl.pivot.utilities.AbstractEnvironmentFactory.dispose(AbstractEnvironmentFactory.java:669)
at org.eclipse.ocl.pivot.utilities.AbstractEnvironmentFactory.detach(AbstractEnvironmentFactory.java:649)
at org.eclipse.ocl.pivot.utilities.ThreadLocalExecutor.setEnvironmentFactory(ThreadLocalExecutor.java:414)
at org.eclipse.ocl.xtext.base.ui.utilities.ThreadLocalExecutorUI.localInitPart(ThreadLocalExecutorUI.java:109)
at org.eclipse.ocl.xtext.base.ui.utilities.ThreadLocalExecutorUI.initPart(ThreadLocalExecutorUI.java:53)
at org.eclipse.ocl.xtext.base.ui.model.BaseDocumentProvider.initOCL(BaseDocumentProvider.java:75)
at org.eclipse.ocl.xtext.base.ui.BaseEditor.setDocumentProvider(BaseEditor.java:61)
at org.eclipse.xtext.ui.editor.XtextEditor.init(XtextEditor.java:289)
at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:353)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:344)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:976)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:938)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:138)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:385)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:311)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:203)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:91)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:42)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:132)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:995)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:659)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:763)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:728)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:47)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:712)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.lambda$0(PartServiceImpl.java:105)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.lambda$0(UIEventHandler.java:38)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:183)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:5959)
at org.eclipse.e4.ui.workbench.swt.DisplayUISynchronize.syncExec(DisplayUISynchronize.java:34)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:208)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:206)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:133)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElementGen(ElementContainerImpl.java:170)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:188)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:661)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:625)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:796)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1270)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3233)
at org.eclipse.ui.internal.WorkbenchPage.lambda$11(WorkbenchPage.java:3123)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3121)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3091)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3082)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:548)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:508)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:367)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:172)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:288)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:254)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:274)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:252)
at org.eclipse.jdt.internal.ui.navigator.OpenAndExpand.run(OpenAndExpand.java:53)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:215)
at org.eclipse.ui.navigator.CommonNavigatorManager$1.open(CommonNavigatorManager.java:184)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:800)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:174)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:797)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1115)
at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:452)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:296)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:331)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5854)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1529)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:5064)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4516)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:342)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:648)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:555)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:173)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:208)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:402)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:651)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:588)
at org.eclipse.equinox.launcher.Main.run(Main.java:1459)
at org.eclipse.equinox.launcher.Main.main(Main.java:1432)
Of course, loading an OCL file on an .xmi model created with "Create Dynamic Instance" is out of the question (it crashes the editor with a similar stack trace).
Am I doing something particularly wrong? Is my configuration not good in any way? Is this maybe a bug with Complete OCL? I have ran out of options to be honest...
G. D.
FUDForum. Page generated in 0.03396 seconds
