External event queue is full, external event dropped! [message #1863335] |
Sat, 27 January 2024 14:41 |
paulo nunes Messages: 10 Registered: January 2024 |
Junior Member |
Hello, i'm using an 1s E_CYCLE and a CLIENT_0_1 to read one opc_ua variable and the error "External event queue is full, external event dropped!" keeps appearing at fixed input events, ex.: with FORTE_EventChainExternalEventListSize = 10, the subscribe block freezes after 7 events in REQ and some time after, the error appears. with FORTE_EventChainExternalEventListSize = 100 the error shows after 50 events in REQ.
There is some way to fix this?
[Updated on: Sat, 27 January 2024 14:46] Report message to a moderator
Re: External event queue is full, external event dropped! [message #1863438 is a reply to message #1863395] |
Fri, 02 February 2024 12:17 |
Junior Member |
I don't think it's the same issue, as i'm using open62541 v1.0 without security and my communication works for some time, dropping after a fix amount of events. Probably it's some setting regarding the RTOS, because i'm using the FORTE machine on esp32. I will try to adjust the settings and will give a feedback here if it works.
EDIT: Apparently, there is no issue when i use SUBSCRIBE function with subscribe block, which i think is a better solution than a client block with e_cycle.
[Updated on: Mon, 12 February 2024 15:26] Report message to a moderator
FUDForum. Page generated in 0.03702 seconds
