Build 4diac FORTE for Multiple Target (aarch64, aarch64 with musl, x86_64, x86_w64) on WSL [message #1863266] |
Sat, 20 January 2024 17:28 |
Ketut Kumajaya Messages: 26 Registered: January 2024 |
Junior Member |
Build 4diac FORTE for Multiple Target on WSL
Meanwhile, this is for the Raspberry Pi 4B and Windows targets, although I have also done it for the Ubuntu 20.04 server.
I wrote it as personal blog content but you can asking related questions here.
UPDATE:
I decided to upgrade Ubuntu WSL from 22.04 LTS "Jammy Jellyfish" to 24.04 LTS "Noble Numbat" to use gcc-mingw-w64 and g++-mingw-w64 packages from Ubuntu distribution but had a problem with FORTE that compilation result did not run without any error message. In order for FORTE compilation results run successfully we have to change gcc and g++ thread model from default win32 to posix, do the following:
$ sudo update-alternatives --set x86_64-w64-mingw32-gcc /usr/bin/x86_64-w64-mingw32-gcc-posix
$ sudo update-alternatives --set x86_64-w64-mingw32-g++ /usr/bin/x86_64-w64-mingw32-g++-posix
UPDATE:
Upgrade to Ubuntu 24.04 make me feel stupid because the compilation result for Raspberry doesn't work anymore with an error message "/lib/aarch64-linux-gnu/libc.so.6: version `GLIBC_2.38' not found" even though I compiled using gcc version 11. Incompatible libc version!
I suggest sticking with Ubuntu version 22.04 or switch to GNU toolchain from Arm but then requires an adjustments in compilation: change compiler from aarch64-linux-gnu-* to aarch64-none-linux-gnu-*
$ cd
$ wget -c https://armkeil.blob.core.windows.net/developer/Files/downloads/gnu/11.3.rel1/binrel/arm-gnu-toolchain-11.3.rel1-x86_64-aarch64-none-linux-gnu.tar.xz
$ tar xvf arm-gnu-toolchain-11.3.rel1-x86_64-aarch64-none-linux-gnu.tar.xz
$ export PATH=$HOME/arm-gnu-toolchain-11.3.rel1-x86_64-aarch64-none-linux-gnu/bin:$PATH
UPDATE:
Attached 2 patch to fix modbus build and com raw layer to fix MQTT data publishing/subscribing.
[Updated on: Thu, 01 February 2024 10:49] Report message to a moderator
Re: Build 4diac FORTE for Multiple Target on WSL [message #1863397 is a reply to message #1863392] |
Wed, 31 January 2024 09:35 |
would you mind posting different discussion topics in different forum topics. This helps me and others to better keep track and later search for it.
We are on our journey to migrate the 4diac FORTE repo to github. Would you be able to provide PR requests there?
Anything that makes 4diac FORTE's open62541 and OPC UA usage more secure would be great. However I'm not an expert on that topic.
FUDForum. Page generated in 0.03217 seconds
