closed noob mosquitto installation on armbian question [message #1862208] |
Fri, 17 November 2023 15:17 |
bert meijer Messages: 3 Registered: November 2023 |
Junior Member |
I'm trying to make a server for all the sensors on my boat.
To do this I installed armbian on a solar powered bananapi m2 zero. And installed mosquito with the following commands:
wget (I'm not allowed to use links because I'm a new user) link to mosquito-repo. Gpg. Key
sudo apt-key add mosquitto-repo.gpg.key
cd /etc/apt/sources.list.d/
sudo wget (I'm not allowed to use links because I'm a new user), repo.mosquitto.org/debian/mosquitto-bookworm.list
apt-get update
sudo apt install mosquitto mosquitto-clients
It gave a warning about apt.key being depreciated but installed ok.
Once this was done, I tested it and it worked.
then I tried to secure my mosquitto broker following information on a digitalOcean site (Suggested by google)
I executed the following commands:
sudo mosquitto_passwd -c /etc/mosquitto/passwd bert
And made a default.conf file with:
sudo nano /etc/mosquitto/conf.d/default.conf
containing the following:
allow_anonymous false
password_file /etc/mosquitto/passwd
With a trailing newline, (which I think is a enter after the last command?)
Following this, I attempted to restart the broker using:
sudo systemctl restart mosquitto
Witch didn't work and gave the following error:
Job for mosquitto.service failed because the control process exited with error code.
See "systemctl status mosquitto.service" and "journalctl -xeu mosquitto.service" for details.
I tried "systemctl status mosquitto.service":
× mosquitto.service - Mosquitto MQTT Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Fri 2023-11-17 13:51:30 UTC; 23s ago
Duration: 5min 51.900s
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Process: 2887 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 2888 ExecStartPre=/bin/chown mosquitto:mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 2889 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 2890 ExecStartPre=/bin/chown mosquitto:mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 2891 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=13)
Main PID: 2891 (code=exited, status=13)
CPU: 78ms
Nov 17 13:51:30 bananapim2zero systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
Nov 17 13:51:30 bananapim2zero systemd[1]: Stopped mosquitto.service - Mosquitto MQTT Broker.
Nov 17 13:51:30 bananapim2zero systemd[1]: mosquitto.service: Start request repeated too quickly.
Nov 17 13:51:30 bananapim2zero systemd[1]: mosquitto.service: Failed with result 'exit-code'.
Nov 17 13:51:30 bananapim2zero systemd[1]: Failed to start mosquitto.service - Mosquitto MQTT Broker.
and "journalctl -xeu mosquitto.service" :
Journal file /var/log/journal/328157c716ca4f31b87372199f6889af/system@7c838c84ba3a4aaa9397b855e925ae88-0000000000000001-000604394ba7f577.journal is truncated, ignoring file.
░░ Automatic restarting of the unit mosquitto.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
░░ Subject: A stop job for unit mosquitto.service has finished
░░ Defined-By: systemd
░░ Support:(I'm not allowed to use links because I'm a new user) debian.org/support
░░ A stop job for unit mosquitto.service has finished.
░░ The job identifier is 1605 and the job result is done.
░░ Subject: Unit failed
░░ Support: (I'm not allowed to use links because I'm a new user).debian.org/support
░░ The unit mosquitto.service has entered the 'failed' state with result 'exit-code'.
░░ Subject: A start job for unit mosquitto.service has failed
░░ A start job for unit mosquitto.service has finished with a failure.
░░ The job identifier is 1605 and the job result is failed.
I feel like it's something simple, but I'm not sure what it is.
Can somebody please help me so I can move on to enable SSL encryption, install nodejs and node-red and start playing around with the sensors I have.
Help would be greatly appreciated
[Updated on: Sun, 26 November 2023 20:55] Report message to a moderator
FUDForum. Page generated in 0.03310 seconds
