HelloScout not working with Eclipse 2023-09 [message #1861200] |
Thu, 28 September 2023 20:00 |
Michel R Messages: 46 Registered: April 2015 |
Member |
Hello, Thank you for the new 23.2 version !
However I don't know if it is my installation or what, but I can't make the helloscout application work with Eclipse 2023-09 and the template #23.2.2 or #23.2.4 (those available under Eclipse when creating a new Scout project).
Here is what I do:
- start Eclipse 2023-09
- create 'helloscout2324' project with the template 23.2.4
- Eclipse builds the thing
- Run the combo "js build" + server + client
- Some stuff is done by the script then the server and client application are started by jetty
- Connect to http://localhost:8082/
- I get this error in my browser :
HTTP ERROR 404 Not Found
URI: /
STATUS: 404
MESSAGE: Not Found
SERVLET: UiServlet
The client's trace gives:
2023-09-28 21:49:38,520 INFO [main] org.eclipse.scout.dev.jetty.JettyServer.logServerReady(JettyServer.java:159) - Server ready. The application is available on the following addresses:
http://bquiet:8082/
http://192.168.0.19:8082/
To shut the server down, type "shutdown" in the console.
2023-09-28 21:51:27,203 WARN [qtp1497845528-96] org.eclipse.scout.rt.server.commons.authentication.DevelopmentAccessController.handle(DevelopmentAccessController.java:65) - +++ Development access control with user michel
2023-09-28 21:51:49,023 INFO [qtp1497845528-96] org.eclipse.scout.rt.ui.html.UiServlet.sendNotFound(UiServlet.java:282) - 404_NOT_FOUND: GET /
Same with the template 23.2.2.
I did this try because I had the same problem with the application I try to upgrade.
Java version is 17.
OS is Windows 11.
The browser is a recent Firefox.
Is it my fault or can it be reproduced ?
[Updated on: Thu, 28 September 2023 20:02] Report message to a moderator
FUDForum. Page generated in 0.03813 seconds
