How to use tycho plugin [message #1860728] |
Wed, 30 August 2023 07:33 |
sumegh thale Messages: 1 Registered: August 2023 |
Junior Member |
Hello All,
I'm encountering issues with dependency management while using the Tycho plugin in my Eclipse project. I have set up my POM file with the necessary dependencies, including those required for Xtend and other components. However, during the build process, I'm facing errors related to unresolved dependencies.
I have specified the dependencies in the <dependencies> section of my POM file, and I have also configured the Tycho plugin with the necessary settings for building Eclipse plugins and bundles. Despite this, the build process is not able to resolve these dependencies properly.
I've tried cleaning the project, checking for compatibility issues between Tycho, Eclipse, and Maven versions, and carefully reviewing the build logs with the DEBUG log level enabled for the Tycho plugin. However, I'm still unable to identify the root cause of the dependency resolution problem.
Has anyone else encountered similar issues with Tycho and dependency management? Are there any common pitfalls or best practices I should be aware of when configuring dependencies for Tycho projects? Any insights or suggestions would be greatly appreciated.
Thank you in advance for your help!
FUDForum. Page generated in 0.07833 seconds
