IDE Core Dump after glib/webgtk update [message #1859178] |
Wed, 17 May 2023 16:28 |
Robert A Messages: 1 Registered: May 2023 |
Junior Member |
Hey everyone.
After an update (see Update list in attachments), Eclipse IDE (2020-12(4.18)) is crashing when using eg. Autocompletion
Regarding the Stack-Trace it may gets caused from webgtk.
Stack: [0x00007ff136919000,0x00007ff136a19000], sp=0x00007ff136a14908, free space=1006k
Native frames: (J=compiled Java code, A=aot compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [libswt-gtk-4940r23.so+0x36f48] Java_org_eclipse_swt_internal_C_strlen+0xf
j org.eclipse.swt.internal.Converter.cCharPtrToJavaString(JZ)Ljava/lang/String;+1
j org.eclipse.swt.browser.WebKit$WebKitExtension.initializeWebExtensions_callback(JJ)V+178
I already tried to revert the webgtk update to the last known working without success. IDE keeps crashing.
As you can see in the Error-Log file, some libs are derived from the bundled java version (my IDE comes with a bundled Java-Version).
Maybe it's also related to glib2 update. Sadly, if i revert the glib2 update (+ all dependent packages), lightdm keeps crashing. I guess there are to many dependencies.
Maybe on of you guys can provide some helpful feedback, if this issue is solveable.
Btw. I'm not able to update the IDE to a newer Version, because our Project is bundled to that specific targetplatform.
Thank you very much.
Robert
FUDForum. Page generated in 0.02678 seconds
