Re: Problem with Step 1 Use 4diac Locally (Blinking Tutorial). [message #1858906 is a reply to message #1858886] |
Sat, 29 April 2023 19:39 |
I'm sorry that our tutorials are not up to date. We are in a transition phase and were not able to keep our tutorials up to date. Any support here would be greatly appreciated.
Regarding your issues:
ad 1) in one of the last versions we allowed that certain data types have own colors. This can help users to better identify what is going on. So that you see the boolean pins in a grey style is perfectly fine. If you would like to change these colors there is a dedicated preference page for that.
ad 2) the deployment perspective was removed as it didn't add any value. For launching 4diac FORTEs you can use the simulated device manager. Deploying works by selecting the element to deploy (e.g., system, device resource) and in the context menu select the deploy menue entry.
If you would like to provide us with new screenshots or update text. The tutorials are part of the 4diac IDE source code. There you can find html files with them. As said any support on this topic would be amazing.
Alois
FUDForum. Page generated in 0.03213 seconds
