Re: INTO-CPS tool [message #1858843 is a reply to message #1858842] |
Wed, 26 April 2023 09:32 |
What I forgot to mention our FMI/FMU support was not used to much recently. So you may need to update some code. Would be happy if you can give us feedback and if needed and possible if you could provide fixes for it.
Re: INTO-CPS tool [message #1858905 is a reply to message #1858903] |
Sat, 29 April 2023 13:55 |
Hi Javier,
welcome to Eclipse 4diac. I'm sorry that Eclipse 4diac gives you a hard time. We are currently in a kind of transition phase and not everything is already synced. I assume you are using the official last release of 4diac IDE and 4diac FORTE. There 4diac FORTE requires the 1.0 release of open62541. Unfortunately open62541 did a non compatible change in the 1.1 or 1.2 release.
If you want to use the latest open62541release 1.3.4 you need our 4diac FORTE prerelease. The best is you clone our 4diac FORTE git repository and take from that the freeze branch.
However to use the 4diac FORTE freeze version you need also the pre-release version of 4diac IDE from the upcoming Eclipse 4diac 3.0 release. You can get this at: https://download.eclipse.org/4diac/updates/rc/
I hope this helps.
FUDForum. Page generated in 0.06455 seconds
