Re: Accordion field, height [message #1858142 is a reply to message #1857904] |
Fri, 17 March 2023 08:04 |
A group is always as height as its content wants to be. Since a group does not use the logical grid layout, setting grid properties on the table field won't have any effect. Have you tried adding some rows? The table (and hence the group) should get bigger the more rows you add.
You can use inner classes to create the group and the table as you would do within a group box. But you can also create them outside as you tried, both should work.
If want want the table to be bigger without rows you could try using CSS and setting a min-height. Or you could wrap the TableField in a GroupBox. Because a GroupBox uses the logical grid, you should be able to use the grid properties of the TableField.
FUDForum. Page generated in 0.04057 seconds
