Re: Validation Delegate noy found [message #1857744 is a reply to message #1857743] |
Thu, 23 February 2023 14:09 |
I am running in Eclipse, I assume that there is a hidden failure during startup, it seems to work in a different installation.
When I see "seems to" I mean that I do not get the error message from the ECore Validator, while I *do* receive the message if I add an unknown URL. I have not added or tested any features that require the delegate.
I am not sure how the validation error is generated, and which debug I should set. However, it is an effect that is likely due to the installation. So I need to find that difference.
[Updated on: Thu, 23 February 2023 14:12] Report message to a moderator
Re: Validation Delegate noy found [message #1857749 is a reply to message #1857747] |
Fri, 24 February 2023 00:04 |
Case closed, error log revealed broken config data for PDE plugin. Once I switched workspace, the message went away and things started working. I can only assume it caused reading of later registries to fail somehow. What was confusing me was that the plugin registry view showed ecore plugin and extending OCL plugin loaded, yet the AnnotationValidationDelegate did not find the annotation. I was not asking for help, just for time to go after it. I am very grateful for attention to details. I can see your message count, so I know the work you invest, not just in your code.
FUDForum. Page generated in 0.04147 seconds
