Re: EMF Forms evaluation [message #1856822 is a reply to message #1856663] |
Wed, 04 January 2023 12:16 |
Jonas Helming Messages: 111 Registered: September 2016 |
you do not really have to have RCP knowledeg to use EMF Forms. However, if you want to embed EMF Forms into an RCP application, this would obviously require some RCP knowledge.
About the second question: Yes you can show attributes of sub elements of a parent in the same form. By default, this is supported for 1:1 containment references, e.g. a person has an address. In this case you can show all attributes of adress in the form of the person. This also works for references with multiplicity many, although usually you want to use a table then.
Jonas
Jonas Helming
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.03471 seconds
