Home » Eclipse Projects » Mosquitto » Broker not sending all retained messages(200 topics updated in broker, with retained messages. When client connects, broker only sends 120 messages, not 200)
Broker not sending all retained messages [message #1856379] |
Wed, 07 December 2022 23:50 |
Garrett Brennan Messages: 4 Registered: December 2022 |
Junior Member |
This is my first time using this forum.
Set Up
I installed Mosquitto v1.6.9 on a Linux machine (which runs inside a virtual machine).
I have two clients.
Client A publishes one message to each of 200 topics. These messages are set with QoS = 1.
Using MQTT Explorer, I can verify that all 200 messages were received by the broker.
Client B connects, and subscribes to all topics.
The broker sends the first 120 topic messages, and not the remaining 80.
Additional information / Things I have tried
ONE
I have tried this with QoS=1, and QoS=2
- same result
TWO
I added the following line to my local config file (even though I know the default should be 1000, but I just wanted to see if there would be any change):
max_queued_messages = 250
- same result
THREE
Then I added another line
max_inflight_messages 1
- same result
FOUR
I viewed the mosquito broker's PUBLISH and PUBACK messages, and verified that
(a) all 200 messages are sent by Client A with retain flag true, and
(b) that only 120 messages are published to Client B when it logs on.
- I have pasted an example of this at the end of this post
FIVE
I testing the same scenario (200 topics) on some of the public/free MQTT brokers:
HiveMQ (broker.hivemq.com) Client B got all 200 messages
MQTTHQ (public.mqtthq.com) Client B got all 200 messages
EMQX (broker.emqx.io) Client B only got 42 messages
So I am seeing something similar from the EMQX public broker
QUESTION
Can any see what I might be missing?
Thank you
Garrett
Example of PUBLISH messages received by broker from Client A
Received PUBLISH from my_publisher (d0, q2, r1, m61962, 'ui/ui120/a', ... (119 bytes))
Received PUBLISH from my_publisher (d0, q2, r1, m61962, 'ui/ui121/a', ... (119 bytes))
Received PUBLISH from my_publisher (d0, q2, r1, m61962, 'ui/ui122/a', ... (119 bytes))
Received PUBLISH from my_publisher (d0, q2, r1, m61962, 'ui/ui123/a', ... (119 bytes))
Example of PUBLISH to Client B, and PUBACKs back from Client B
New client connected from xxx.xxx.xxx.xx as my_client' (p2, c0, k0).
No will message specified.
Sending CONNACK to my_client' (1, 0)
Sending PUBLISH to my_client' (d1, q1, r0, m2612, 'ui/ui001/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2613, 'ui/ui002/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2614, 'ui/ui003/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2615, 'ui/ui004/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2616, 'ui/ui005/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2617, 'ui/ui006/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2618, 'ui/ui007/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2619, 'ui/ui008/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2620, 'ui/ui009/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2621, 'ui/ui010/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2622, 'ui/ui011/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2623, 'ui/ui012/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2624, 'ui/ui013/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2625, 'ui/ui014/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2626, 'ui/ui015/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2627, 'ui/ui016/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2628, 'ui/ui017/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2629, 'ui/ui018/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2630, 'ui/ui019/a', ... (119 bytes))
Sending PUBLISH to my_client' (d1, q1, r0, m2631, 'ui/ui020/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2632, 'ui/ui021/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2633, 'ui/ui022/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2634, 'ui/ui023/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2635, 'ui/ui024/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2636, 'ui/ui025/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2637, 'ui/ui026/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2638, 'ui/ui027/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2639, 'ui/ui028/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2640, 'ui/ui029/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2641, 'ui/ui030/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2642, 'ui/ui031/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2643, 'ui/ui032/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2644, 'ui/ui033/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2645, 'ui/ui034/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2646, 'ui/ui035/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2647, 'ui/ui036/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2648, 'ui/ui037/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2649, 'ui/ui038/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2650, 'ui/ui039/a', ... (119 bytes))
Sending PUBLISH to my_client' (d0, q1, r0, m2651, 'ui/ui040/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2612, RC:0)
Received PUBACK from my_client' (Mid: 2613, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2652, 'ui/ui041/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2614, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2653, 'ui/ui042/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2615, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2654, 'ui/ui043/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2616, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2655, 'ui/ui044/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2617, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2656, 'ui/ui045/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2618, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2657, 'ui/ui046/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2619, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2658, 'ui/ui047/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2620, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2659, 'ui/ui048/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2621, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2660, 'ui/ui049/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2622, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2661, 'ui/ui050/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2623, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2662, 'ui/ui051/a', ... (117 bytes))
Received PUBACK from my_client' (Mid: 2624, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2663, 'ui/ui052/a', ... (118 bytes))
Received PUBACK from my_client' (Mid: 2625, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2664, 'ui/ui053/a', ... (118 bytes))
Received PUBACK from my_client' (Mid: 2626, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2665, 'ui/ui054/a', ... (118 bytes))
Received PUBACK from my_client' (Mid: 2627, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2666, 'ui/ui055/a', ... (118 bytes))
Received PUBACK from my_client' (Mid: 2628, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2667, 'ui/ui056/a', ... (118 bytes))
Received PUBACK from my_client' (Mid: 2629, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2668, 'ui/ui057/a', ... (118 bytes))
Received PUBACK from my_client' (Mid: 2630, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2669, 'ui/ui058/a', ... (118 bytes))
Received PUBACK from my_client' (Mid: 2631, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2670, 'ui/ui059/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2632, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2671, 'ui/ui060/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2633, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2672, 'ui/ui061/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2634, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2673, 'ui/ui062/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2635, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2674, 'ui/ui063/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2636, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2675, 'ui/ui064/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2637, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2676, 'ui/ui065/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2638, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2677, 'ui/ui066/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2639, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2678, 'ui/ui067/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2640, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2679, 'ui/ui068/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2641, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2680, 'ui/ui069/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2642, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2681, 'ui/ui070/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2643, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2682, 'ui/ui071/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2644, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2683, 'ui/ui072/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2645, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2684, 'ui/ui073/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2646, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2685, 'ui/ui074/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2647, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2686, 'ui/ui075/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2648, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2687, 'ui/ui076/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2649, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2688, 'ui/ui077/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2650, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2689, 'ui/ui078/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2651, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2690, 'ui/ui079/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2652, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2691, 'ui/ui080/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2653, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2692, 'ui/ui081/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2654, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2693, 'ui/ui082/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2655, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2694, 'ui/ui083/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2656, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2695, 'ui/ui084/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2657, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2696, 'ui/ui085/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2658, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2697, 'ui/ui086/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2659, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2698, 'ui/ui087/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2660, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2699, 'ui/ui088/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2661, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2700, 'ui/ui089/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2662, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2701, 'ui/ui090/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2663, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2702, 'ui/ui091/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2664, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2703, 'ui/ui092/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2665, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2704, 'ui/ui093/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2666, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2705, 'ui/ui094/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2667, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2706, 'ui/ui095/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2668, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2707, 'ui/ui096/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2669, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2708, 'ui/ui097/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2670, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2709, 'ui/ui098/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2671, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2710, 'ui/ui099/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2672, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2711, 'ui/ui100/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2673, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2712, 'ui/ui101/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2674, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2713, 'ui/ui102/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2675, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2714, 'ui/ui103/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2676, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2715, 'ui/ui104/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2677, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2716, 'ui/ui105/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2678, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2717, 'ui/ui106/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2679, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2718, 'ui/ui107/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2680, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2719, 'ui/ui108/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2681, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2720, 'ui/ui109/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2682, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2721, 'ui/ui110/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2683, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2722, 'ui/ui111/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2684, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2723, 'ui/ui112/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2685, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2724, 'ui/ui113/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2686, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2725, 'ui/ui114/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2687, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2726, 'ui/ui115/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2688, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2727, 'ui/ui116/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2689, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2728, 'ui/ui117/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2690, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2729, 'ui/ui118/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2691, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2730, 'ui/ui119/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2692, RC:0)
Sending PUBLISH to my_client' (d0, q1, r0, m2731, 'ui/ui120/a', ... (119 bytes))
Received PUBACK from my_client' (Mid: 2693, RC:0)
Received PUBACK from my_client' (Mid: 2694, RC:0)
Received PUBACK from my_client' (Mid: 2695, RC:0)
Received PUBACK from my_client' (Mid: 2696, RC:0)
Received PUBACK from my_client' (Mid: 2697, RC:0)
Received PUBACK from my_client' (Mid: 2698, RC:0)
Received PUBACK from my_client' (Mid: 2699, RC:0)
Received PUBACK from my_client' (Mid: 2700, RC:0)
Received PUBACK from my_client' (Mid: 2701, RC:0)
Received PUBACK from my_client' (Mid: 2702, RC:0)
Received PUBACK from my_client' (Mid: 2703, RC:0)
Received PUBACK from my_client' (Mid: 2704, RC:0)
Received PUBACK from my_client' (Mid: 2705, RC:0)
Received PUBACK from my_client' (Mid: 2706, RC:0)
Received PUBACK from my_client' (Mid: 2707, RC:0)
Received PUBACK from my_client' (Mid: 2708, RC:0)
Received PUBACK from my_client' (Mid: 2709, RC:0)
Received PUBACK from my_client' (Mid: 2710, RC:0)
Received PUBACK from my_client' (Mid: 2711, RC:0)
Received PUBACK from my_client' (Mid: 2712, RC:0)
Received PUBACK from my_client' (Mid: 2713, RC:0)
Received PUBACK from my_client' (Mid: 2714, RC:0)
Received PUBACK from my_client' (Mid: 2715, RC:0)
Received PUBACK from my_client' (Mid: 2716, RC:0)
Received PUBACK from my_client' (Mid: 2717, RC:0)
Received PUBACK from my_client' (Mid: 2718, RC:0)
Received PUBACK from my_client' (Mid: 2719, RC:0)
Received PUBACK from my_client' (Mid: 2720, RC:0)
Received PUBACK from my_client' (Mid: 2721, RC:0)
Received PUBACK from my_client' (Mid: 2722, RC:0)
Received PUBACK from my_client' (Mid: 2723, RC:0)
Received PUBACK from my_client' (Mid: 2724, RC:0)
Received PUBACK from my_client' (Mid: 2725, RC:0)
Received PUBACK from my_client' (Mid: 2726, RC:0)
Received PUBACK from my_client' (Mid: 2727, RC:0)
Received PUBACK from my_client' (Mid: 2728, RC:0)
Received PUBACK from my_client' (Mid: 2729, RC:0)
Received PUBACK from my_client' (Mid: 2730, RC:0)
Received PUBACK from my_client' (Mid: 2731, RC:0)
Current Time: Thu May 02 20:37:01 GMT 2024
Powered by FUDForum. Page generated in 0.02818 seconds
