Re: Raspi installation problems [message #1855211 is a reply to message #1855204] |
Sat, 01 October 2022 13:43 |
I think it looks like your docs are not as accurate as they should be. After the first run of CMake it is normal that you have an error. The reason for this is that 4diac FORTE supports so many operating systems which we normally can not really guess. Therefore the minimum setting you have to do after the first run is the set the FORTE_ARCHITECTURTE versiable to the operating system you like to use. For raspi this is posix.
Furthermore CMake GUI is a bit strange with the red marked options. These are options that where newly introduced by a configuration run. In 4diac FORTE this can happen not only after the first run but also after consecutive runs. The reason is that options that you activate require additional configuration settings (e.g., when enabling OPC UA you need to give us the directory with the lib and include files).
When you get the information that there are errors please always check the text ouptput at the bottom of the CMake GUI screen.
Further information about building 4diac FORTE can also be found in the general building 4diac FORTE from source documentation page.
I hope this helps.
Alois
PS: If you have improvement suggestions for our documentation we would be happy to get them. You can easily contribute to our documentation by cloning the 4diac IDE repository and update the html file that can be found in the directory plugins/org.eclispe.fordiac.ide/html,.
FUDForum. Page generated in 0.03587 seconds
