cannot build git contacts [message #1849909] |
Tue, 08 February 2022 11:50 |
Martin Wyser Messages: 4 Registered: February 2022 |
Junior Member |
I cloned the org.eclipse.scout.docs repo, and import the contacts directory. When I run "[contacts] all windows", I get this error:
[contacts] js build windows
Installing 'pnpm' into ../../node_modules
up to date, audited 2 packages in 948ms
1 package is looking for funding
run `npm fund` for details
found 0 vulnerabilities
Running 'pnpm install' in C:\Users\myname\Projects\EclipseScout\org.eclipse.scout.docs\code
Der Befehl "node_modules\pnpm" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
I have eclipse scout 2021-06, which is eclipse scout 22, a beta, on Java 11. I tried previous versions of eclipse scout, but they were all scout 22, down to 2019-12, which I could not run (does not accept any of my JREs).
I have a dedicated writable node installation in the path, with pnpm already installed. When I use a cmd.exe in the the code directory, I get
ERR_PNPM_NO_MATCHING_VERSION No matching version found for @eclipse-scout/cli@11.0.0-snapshot
The latest release of @eclipse-scout/cli is "22.0.0-beta.5".
Other releases are:
* alpha: 11.0.4-beta.2
If you need the full list of all 53 published versions run "$ pnpm view @eclipse-scout/cli versions".
Progress: resolved 3, reused 3, downloaded 0, added 0
What now?
Re: cannot build git contacts [message #1849921 is a reply to message #1849909] |
Tue, 08 February 2022 14:29 |
Junior Member |
I made some progress:
* find all files below directory code (the parent of contacts), grep for 11.0.0-snapshot, change that to 11.0.2.
* "pnpm install" in directory code
There were about 30 occurences of snapshot string.
I can now do "pnpm install" manually, but still in eclipse, the "all" run-configuration does not work. The server works, but not the ui server.
How do I do a js build manually?
[Updated on: Tue, 08 February 2022 14:57] Report message to a moderator
Re: cannot build git contacts [message #1849949 is a reply to message #1849921] |
Wed, 09 February 2022 14:52 |
Matthias Villiger Messages: 232 Registered: September 2011 |
Hi Martin
You are right, the 11.0 branch of the docs sample applications (https://github.com/bsi-software/org.eclipse.scout.docs/tree/releases/11.0/code/) is configured to use Scout 11.0.0-snapshot. This only works if you have a Scout runtime 11.0.0-snapshot locally as no snapshot dependencies are publish to npmjs.com.
If you want to use a fixed Scout release instead, you can
1. replace all "11.0-SNAPSHOT" strings in the pom.xml files to e.g. 11.0.42
2. replace all "11.0.0-snapshot" strings in package.json files to e.g. 11.0.42
Then you might need to do a Maven update in your IDE to fetch the corresponding version.
Then the docs repo is currently configured to install dependencies of all demo applications in one step. As you only want to build the contacts app, you can remove all lines starting with " - 'widgets" from the pnpm-workspace.yaml file in your "code" folder (above the contacts app). Then only one package should remain.
And finally, as you have already pnpm installed locally, you can remove the pnpm installation and use your local pnpm instead (please note that pnpm should be on your PATH). You can do that by modifying the "[contacts] js build.cmd" file as follows:
1. Remove the section named ":: Install pnpm". Most importantly the line "call npm install pnpm@ ..."
2. Change the line calling pnpm "call node_modules\pnpm install --ignore-scripts" to use the one on your PATH by removing the "node_modules\" so that it looks like "call pnpm install --ignore-scripts"
If you then start the "all" run configuration, does it work?
Generally to execute the js build manually you need to
1. have all dependencies installed. This can be done with the command "pnpm install --ignore-scripts"
2. starting the js build and the watcher for automatic hotcode replace with the command "npm run build:dev:watch" in the org.eclipse.scout.contacts.ui.html directory. Or use the script "build:dev" instead of "build:dev:watch" if you just want to build without starting the hotcode replace watcher. For a list of scripts check the package.json file.
Kind regards
Mat
[Updated on: Wed, 09 February 2022 14:54] Report message to a moderator
FUDForum. Page generated in 0.03789 seconds
