Home » Eclipse Projects » WindowBuilder » Window builder fails to install(Tried to install window builder 1.9.7, it fails to install)
Window builder fails to install [message #1849217] |
Sun, 09 January 2022 05:32 |
EDGAR CHAVEZ Messages: 1 Registered: January 2022 |
Junior Member |
I tried installing Window builder from market place, but it doesn't show up in the "New->Other" menu list. So, I can't even create a SWT project.
I tried using the "Install New Software" options but I receive the following error messages:
An error occurred while collecting items to be installed
session context was:(profile=C__Program Files_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.wb.doc.user,1.9.1.202106041225
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.doc.user.feature,1.9.7.202106041225
No repository found containing: osgi.bundle,org.eclipse.wb.rcp.SWT_AWT,1.9.1.202106041225
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.rcp.SWT_AWT_support,1.9.7.202106041225
No repository found containing: osgi.bundle,org.eclipse.wb.rcp.doc.user,1.9.1.202106041225
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.rcp.doc.user.feature,1.9.7.202106041225
No repository found containing: osgi.bundle,org.eclipse.wb.swing,1.9.1.202106041225
No repository found containing: osgi.bundle,org.eclipse.wb.swing.FormLayout,1.9.1.202106041225
No repository found containing: osgi.bundle,org.eclipse.wb.swing.FormLayout.lib,1.9.1.202106041225
No repository found containing: osgi.bundle,org.eclipse.wb.swing.MigLayout,1.9.1.202106041225
No repository found containing: osgi.bundle,org.eclipse.wb.swing.MigLayout.lib,1.9.1.202106041225
No repository found containing: osgi.bundle,org.eclipse.wb.swing.databinding,1.9.1.202106041225
No repository found containing: osgi.bundle,org.eclipse.wb.swing.doc.user,1.9.1.202106041225
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.swing.doc.user.feature,1.9.7.202106041225
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.swing.feature,1.9.7.202106041225
No repository found containing: osgi.bundle,org.eclipse.wb.swing.java6,1.9.1.202106041225
No repository found containing: osgi.bundle,org.eclipse.wb.swing.jsr296,1.9.1.202106041225
Current Time: Sun May 05 13:11:58 GMT 2024
Powered by FUDForum. Page generated in 0.03305 seconds
