Re: Cannot access http://download.eclipse.org/releases/neon/ with DAVE IDE [message #1849064 is a reply to message #1849041] |
Sat, 01 January 2022 11:16 |
Peter Lankton Messages: 5 Registered: December 2021 |
Junior Member |
is that a setting? because just writing https gives a similar error, see first post.
edit:
see here the full error log using: https://download.eclipse.org/releases/neon/
!ENTRY APPLICATION_MODEL 1 0 2022-01-01 12:21:23.770
!MESSAGE Only One DAVE Application is running
!ENTRY org.eclipse.equinox.p2.core 4 0 2022-01-01 12:21:52.067
!MESSAGE Provisioning exception
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: HTTP Server Unknown HTTP Response Code (301):http://download.eclipse.org/technology/epp/packages/neon/content.xml
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:243)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:66)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:88)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:668)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.addChild(CompositeMetadataRepository.java:166)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.<init>(CompositeMetadataRepository.java:106)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:122)
at org.eclipse.equinox.p2.ui.ProvisioningUI.loadMetadataRepository(ProvisioningUI.java:440)
at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getMetadataRepository(MetadataRepositoryElement.java:126)
at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.fetchChildren(MetadataRepositoryElement.java:75)
at org.eclipse.equinox.internal.p2.ui.model.RemoteQueriedElement.fetchDeferredChildren(RemoteQueriedElement.java:34)
at org.eclipse.ui.progress.DeferredTreeContentManager$1.run(DeferredTreeContentManager.java:231)
Caused by: org.eclipse.ecf.filetransfer.BrowseFileTransferException: General connection error with response code=301
at org.eclipse.ecf.provider.filetransfer.browse.URLFileSystemBrowser.runRequest(URLFileSystemBrowser.java:134)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
... 1 more
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2022-01-01 12:21:52.067
!MESSAGE HTTP Server Unknown HTTP Response Code (301):http://download.eclipse.org/technology/epp/packages/neon/content.xml
!STACK 1
!SUBENTRY 2 org.eclipse.ecf.identity 4 0 2022-01-01 12:21:52.067
!MESSAGE General connection error with response code=301
!ENTRY org.eclipse.equinox.p2.ui 4 0 2022-01-01 12:21:52.067
!MESSAGE Unable to read repository at https://download.eclipse.org/releases/neon.
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at https://download.eclipse.org/releases/neon.
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.addChild(CompositeMetadataRepository.java:185)
Caused by: org.eclipse.equinox.p2.core.ProvisionException: HTTP Server Unknown HTTP Response Code (301):http://download.eclipse.org/technology/epp/packages/neon/content.xml
... 13 more
... 1 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2022-01-01 12:21:52.068
!STACK 1
... 1 more
!SUBENTRY 2 org.eclipse.equinox.p2.transport.ecf 4 1002 2022-01-01 12:21:52.068
!STACK 1
!SUBENTRY 3 org.eclipse.ecf.identity 4 0 2022-01-01 12:21:52.068
!ENTRY org.eclipse.equinox.p2.core 4 0 2022-01-01 12:21:53.659
!STACK 1
at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getRepository(MetadataRepositoryElement.java:115)
at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getQueryable(MetadataRepositoryElement.java:109)
at org.eclipse.equinox.internal.p2.ui.QueryProvider.getQueryDescriptor(QueryProvider.java:88)
at org.eclipse.equinox.internal.p2.ui.model.QueriedElement.fetchChildren(QueriedElement.java:101)
at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.fetchChildren(MetadataRepositoryElement.java:77)
... 1 more
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2022-01-01 12:21:53.660
!STACK 1
!SUBENTRY 2 org.eclipse.ecf.identity 4 0 2022-01-01 12:21:53.660
!ENTRY org.eclipse.equinox.p2.ui 4 0 2022-01-01 12:21:53.660
!STACK 1
... 17 more
... 1 more
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1002 2022-01-01 12:21:53.660
!STACK 1
... 1 more
!SUBENTRY 2 org.eclipse.equinox.p2.transport.ecf 4 1002 2022-01-01 12:21:53.660
!STACK 1
!SUBENTRY 3 org.eclipse.ecf.identity 4 0 2022-01-01 12:21:53.660
[Updated on: Sat, 01 January 2022 11:31] Report message to a moderator
FUDForum. Page generated in 0.03664 seconds
