Re: Object name instead of eProxyURI [message #1846969 is a reply to message #1846965] |
Mon, 11 October 2021 05:03 |
Ed Merks Messages: 33150 Registered: July 2009 |
Did you use the debugger to see why this is not automatically resolved? Something is still wrong if you need to do it manually. But without code, one can only guess.
If you used the debugger, you'd see there the name printed is from in the toString method, and you'd use Open Call Hierarchy on the 'name' field to see that there is a getName method on the implementation EClassImpl which you would see implements that same method declared in an inherited interface of EClass.
Ed Merks
FUDForum. Page generated in 0.03058 seconds
