mosquitto mqtt over websockets [message #1844515] |
Wed, 15 September 2021 18:00 |
mohamed abdulmajid Messages: 1 Registered: October 2020 |
Junior Member |
Hello everyone ☺️. I need to use mosquitto mqtt over websockets. I'm using a raspberry pi as a host server for several tools such as mosquitto broker,node red, influx db, and grafana as a data logging system. I'm trying to use grafana to control a sonoff switch through mqtt. I found this plugin: https://github.com/geeks-r-us/mqtt-panel
that allows grafana to communicate with an mqtt server. I have installed the plugin but i can't connect it to the broker! In the plugin's GitHub page the author have mentioned a limitation says " Due to the MQTT client runs in the browser it can only establish mqtt connection over websockets and can only connect to servers reachable by your browser."
Could you tell me how to establish this connection ?!
FUDForum. Page generated in 0.02554 seconds
