Building with -Dnative=win32.win32.x86_64 fails [message #1844346] |
Fri, 10 September 2021 08:00 |
Ingo Kappler Messages: 10 Registered: June 2021 |
Junior Member |
I tried to reduce the build target by specifieng -Dnative=win32.win32.x86_64. However, although the build succeeds if this is not specified, it now fails with the following error.
Is it some kind of bug? Is a fix needed in build.xml? It happens on R_4.17. Havn't tried other releases.
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 08:00 min
[INFO] Finished at: 2021-09-10T09:53:49+02:00
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:3.0.0:run (natives) on project org.eclipse.swt.win32.win32.x86_64: An Ant BuildException has occured: The following error occurred while executing this line:
[ERROR] C:\y\eclipse.platform.swt\bundles\org.eclipse.swt\buildSWT.xml:761: The following error occurred while executing this line:
[ERROR] C:\y\eclipse.platform.swt\bundles\org.eclipse.swt\buildSWT.xml:852: exec returned: 1
[ERROR] around Ant part ...<ant antfile="build.xml" target="build_libraries" />... @ 4:57 in C:\y\eclipse.platform.swt.binaries\bundles\org.eclipse.swt.win32.win32.x86_64\target\antrun\build-main.xml
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:3.0.0:run (natives) on project org.eclipse.swt.win32.win32.x86_64: An Ant BuildException has occured: The following error occurred while executing this line:
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:215)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:156)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:148)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:117)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:81)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build (SingleThreadedBuilder.java:56)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute (LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:305)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:192)
at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:105)
at org.apache.maven.cli.MavenCli.execute (MavenCli.java:957)
at org.apache.maven.cli.MavenCli.doMain (MavenCli.java:289)
at org.apache.maven.cli.MavenCli.main (MavenCli.java:193)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0 (Native Method)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke (NativeMethodAccessorImpl.java:62)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke (Method.java:566)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced (Launcher.java:282)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch (Launcher.java:225)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode (Launcher.java:406)
at org.codehaus.plexus.classworlds.launcher.Launcher.main (Launcher.java:347)
Caused by: org.apache.maven.plugin.MojoExecutionException: An Ant BuildException has occured: The following error occurred while executing this line:
at org.apache.maven.plugins.antrun.AntRunMojo.execute (AntRunMojo.java:308)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo (DefaultBuildPluginManager.java:137)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:210)
Caused by: org.apache.tools.ant.BuildException: The following error occurred while executing this line:
at org.apache.tools.ant.ProjectHelper.addLocationToBuildException (ProjectHelper.java:571)
at org.apache.tools.ant.taskdefs.Ant.execute (Ant.java:440)
at org.apache.tools.ant.UnknownElement.execute (UnknownElement.java:292)
at jdk.internal.reflect.GeneratedMethodAccessor64.invoke (Unknown Source)
at org.apache.tools.ant.dispatch.DispatchUtils.execute (DispatchUtils.java:99)
at org.apache.tools.ant.Task.perform (Task.java:350)
at org.apache.tools.ant.Target.execute (Target.java:449)
at org.apache.tools.ant.Target.performTasks (Target.java:470)
at org.apache.tools.ant.Project.executeSortedTargets (Project.java:1391)
at org.apache.tools.ant.Project.executeTarget (Project.java:1364)
at org.apache.maven.plugins.antrun.AntRunMojo.execute (AntRunMojo.java:287)
at org.apache.tools.ant.taskdefs.CallTarget.execute (CallTarget.java:106)
at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets (SingleCheckExecutor.java:36)
at org.apache.tools.ant.Project.executeTargets (Project.java:1254)
at org.apache.tools.ant.taskdefs.Ant.execute (Ant.java:437)
Caused by: org.apache.tools.ant.BuildException: exec returned: 1
at org.apache.tools.ant.taskdefs.ExecTask.runExecute (ExecTask.java:645)
at org.apache.tools.ant.taskdefs.ExecTask.runExec (ExecTask.java:669)
at org.apache.tools.ant.taskdefs.ExecTask.execute (ExecTask.java:497)
[ERROR]
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR] mvn <args> -rf :org.eclipse.swt.win32.win32.x86_64
[Updated on: Fri, 10 September 2021 08:50] Report message to a moderator
FUDForum. Page generated in 0.02696 seconds
