eclipse-mosquitto Error: Address not available [message #1843395] |
Tue, 27 July 2021 16:20 |
Robert Binet Messages: 1 Registered: July 2021 |
Junior Member |
eclipse-mosquitto 2.0.11 installed with docker is not working
eclipse-mosquitto 1.6.15 is working correctly
See Below
Robert
LOGS:
2021-07-27T15:42:06: mosquitto version 1.6.15 starting
2021-07-27T15:42:06: Config loaded from /mosquitto/config/mosquitto.conf.
2021-07-27T15:42:06: Opening ipv4 listen socket on port 1883.
2021-07-27T15:42:06: Opening ipv6 listen socket on port 1883.
2021-07-27T15:42:06: mosquitto version 1.6.15 running
2021-07-27T15:42:35: New connection from 172.18.0.1 on port 1883.
2021-07-27T15:42:35: New client connected from 172.18.0.1 as 2Lv60T7bsBJq61DudEOmeb (p2, c1, k60, u'MQTT').
2021-07-27T15:42:38: New connection from 172.18.0.1 on port 1883.
2021-07-27T15:42:38: New client connected from 172.18.0.1 as dd3bbe87-689b-4edc-b635-0f120a6d367c (p2, c1, k60, u'MQTT').
2021-07-27T15:43:07: mosquitto version 1.6.15 terminating
2021-07-27T15:43:07: Saving in-memory database to /mosquitto/datamosquitto.db.
2021-07-27T15:44:02: mosquitto version 2.0.11 starting
2021-07-27T15:44:02: Config loaded from /mosquitto/config/mosquitto.conf.
2021-07-27T15:44:02: Starting in local only mode. Connections will only be possible from clients running on this machine.
2021-07-27T15:44:02: Create a configuration file which defines a listener to allow remote access.
2021-07-27T15:44:02: For more details see
2021-07-27T15:44:02: Opening ipv4 listen socket on port 1883.
2021-07-27T15:44:02: Opening ipv6 listen socket on port 1883.
2021-07-27T15:44:02: Error: Address not available
2021-07-27T15:44:02: mosquitto version 2.0.11 running
CONFIG FILE:
persistence true
persistence_location /mosquitto/data
log_dest file /mosquitto/log/mosquitto.log
# To avoid flash wearing
log_dest stdout
#Uncomment to enable passwords
password_file /mosquitto/pwfile/passwd
allow_anonymous false
#Uncomment to enable filters
#acl_file /mosquitto/config/filter.acl
log_timestamp_format %Y-%m-%dT%H:%M:%S
FUDForum. Page generated in 0.02359 seconds
