Hide table based on sub datasets [message #1842812] |
Fri, 02 July 2021 00:41 |
Shane Cress Messages: 1 Registered: July 2021 |
Junior Member |
Hi all,
I have a detailed report with a main table utilizing the main dataset of the report, then 8 sub tables inside that table each using their own sub dataset, now it seems hiding a subtable is quite easy if the sub dataset returns no records, but in the event that all 8 subtables are empty and hidden, I want to be able to hide the main table and skip the page.
I've tried out a few methods so far, such as creating a Variable and on fetch of a sub dataset, if fetch of any records is successful then increment the variable, then in the main tables visibility, I would check if the variable was equal to 0 and hide if so, but it seems the visibility function on the main table executes before the sub tables run their datasets.
Any suggestions?
FUDForum. Page generated in 0.03196 seconds
