BIRT 4.3.2 Migration issue [message #1840658] |
Wed, 21 April 2021 13:49 |
Tamilselvan K Messages: 6 Registered: February 2021 |
Junior Member |
Unable to see the data in the output Report files as expected right after the BIRT API upgrade to 4.3.2 from 2.2.2 .
I have made the java code changes as 4.3.2 doesn't require the BIRT home setup in the code etc,.
I have plenty of reports and each one of them are having the CSV, XLS and PDF formats. I could see that there are some discrepancies in the output files right after the BIRT upgrade such as footer is missing in CSV format file which is present in other PDF and XLS format.
In some of the reports, even the data rows are missing. I hope i have added the required 4.3.2 jars which were present under BIRT4.3.2/Runtime/lib. Not sure what i am missing yet to achieve the correct results.
Can anyone do me a favor on what are the things to be considered during the BIRT API migration
FUDForum. Page generated in 0.02963 seconds
