genReport.bat event handler class not found [message #1838249] |
Fri, 19 February 2021 14:13 |
Ondřej Duchoň Messages: 1 Registered: February 2021 |
Junior Member |
I have a problem with my birt report engine. I have used version 2.2.0. I have my custom java event handler for image to generate qr codes. When I developed this event handler in eclipse, everything run perfectly.
But when I have tested my event handler with genReport.bat script with reportEngine I get an error:
java.lang.ClassNotFoundException: com.minerva.barcodegen.birt.BIRTQRCodeGenerator
I have edited the genReport.bat file where I am adding my jar file to the classpath like this:
SET BIRTCLASSPATH=%BIRT_HOME%\ReportEngine\lib\chartengineapi.jar;%BIRT_HOME%\ReportEngine\lib\com.ibm.icu_3.6.1.v20070417.jar;%BIRT_HOME%\ReportEngine\lib\commons-cli-1.0.jar;%BIRT_HOME%\ReportEngine\lib\commons-codec-1.3.jar;%BIRT_HOME%\ReportEngine\lib\coreapi.jar;%BIRT_HOME%\ReportEngine\lib\dataadapterapi.jar;%BIRT_HOME%\ReportEngine\lib\dteapi.jar;%BIRT_HOME%\ReportEngine\lib\engineapi.jar;%BIRT_HOME%\ReportEngine\lib\flute.jar;%BIRT_HOME%\ReportEngine\lib\js.jar;%BIRT_HOME%\ReportEngine\lib\modelapi.jar;%BIRT_HOME%\ReportEngine\lib\org.eclipse.emf.common_2.2.1.v200702131851.jar;%BIRT_HOME%\ReportEngine\lib\org.eclipse.emf.ecore_2.2.2.v200702131851.jar;%BIRT_HOME%\ReportEngine\lib\org.eclipse.emf.ecore.xmi_2.2.2.v200702131851.jar;%BIRT_HOME%\ReportEngine\lib\org.w3c.css.sac_1.3.0.v200706111724.jar;%BIRT_HOME%\ReportEngine\lib\scriptapi.jar;%BIRT_HOME%\ReportEngine\lib\barcodegen.jar;
Can you tell me where can I copy my jar file for the birt event handler?
Thank you very much.
FUDForum. Page generated in 0.02576 seconds
