Open broker to specific IP [message #1837950] |
Thu, 11 February 2021 09:45 |
Hello everybody,
i hope you are able to help me.
I installed a mosquitto broker on my win10 machine and was able to publish to a topic with a microcontroller within the local network. In respect to the final purpose of the project i have to use a static IP wich is from another network (local is like "192" and the other is like "172"). I defined a rule to windows firewall wich tells that port 1883 is open in private an public network (at times a tried to connect with a completly shut down firewall but there was no difference) and modified the default "mosquitto.conf" with the following lines:
listener 1883
allow_anonymous true
Is there somebody who can tell me how i could go on?
Best Regards
DerPreuße
Re: Open broker to specific IP [message #1838040 is a reply to message #1838009] |
Sun, 14 February 2021 12:25 |
Hello Roger,
i´ve found something in "mosquitto.conf" that could matter in respect to this problem.
# Defaults to false, unless there are no listeners defined in the configuration
# file, in which case it is set to true, but connections are only allowed from
# the local machine.
allow_anonymous false
So i try to connect in future with 'allow_anonymous' set to false. Couldn´t test it yet but when i do, i´ll report the result of it.
Best Regards
DerPreuße
Re: Open broker to specific IP [message #1838116 is a reply to message #1838040] |
Tue, 16 February 2021 13:51 |
Hello everybody,
it is a network problem. Even with open port (my) network will block accessing devices, if they are from "other side".
So i think one has to configure network setting direct at the router or somewhere like that.
Best Regards
DerPreuße
FUDForum. Page generated in 0.03946 seconds
