BIRT 431 Crosstab [message #1836094] |
Sun, 20 December 2020 18:20 |
Ritu John Messages: 1 Registered: December 2020 |
Junior Member |
Hi all,
Looking for help with an issue I am facing in BIRT 4.3.1. Is it possible to get the BIRT crosstab to display 0 as decimal in empty rows and columns?
I have achieved the display in pdf using show property of crosstab for empty rows/columns. However, when I export it using excel emitter, the 0s are not displayed.
If I export as spreadsheet, the 0 are displayed but as text. But I am forced to use excel emitter since layout and the charts are displayed correctly only in the emitter? As I understand, all the text values are removed in excel emitter from the column where measure is placed.
And I understand that the measure in crosstab does not display 0 as a value. It shows null by default if value is 0. Am I correct? This is what was observed while testing.
Any ideas?
Thanks in Advance
Ritu John
FUDForum. Page generated in 0.03222 seconds
