Error: No model loaded! in IndexExample [message #1834586] |
Fri, 13 November 2020 00:28 |
ruby Shih Messages: 1 Registered: November 2020 |
Hello everyone,
When I try to run the class IndexExample, it shows "Error: No model loaded!".
I'm new to eclipse/java and haven't had clue how to deal with it.
I want to load the existed amalthea model to the program.
The compiler complience is 1.8 and jre is 8.
The version of AMLTHEA model is 1.0.0 and org.eclipse.app4mc.amalthea.model is 0.9.9.
It would be nice if you can give me some advices.
Thank you and best regards,
Ruby
[Updated on: Fri, 13 November 2020 08:26] Report message to a moderator
Re: Error: No model loaded! in IndexExample [message #1835048 is a reply to message #1834586] |
Tue, 24 November 2020 00:31 |
Henning Riedel Messages: 310 Registered: July 2009 |
How come, your Amalthea model (the amxmi file) is 1.0.0, but your o.e.app4mc.amalthea.model (plugin?) is just 0.9.9?
If you use the 0.9.9 version from the app4mc download site, you should only be able to create 0.9.9 versions of the model.
Or, because you said "existing model", is this model somehow taken from a very very old version 1.0.0 of the AMALTHEA-ITEA project? They had there once a 1.0.0 AMALTHEA version around 2014, but when they transfered to Eclipse Foundation, they renumbered APP4MC. If this is true, then I wonder, if there is actually a converter available at all for such an old file.
FUDForum. Page generated in 0.03419 seconds
