Re: Oomph synchronizer with multiple profile? [message #1833830 is a reply to message #1833829] |
Sun, 25 October 2020 09:48 |
Minh Quan Pham Messages: 5 Registered: October 2020 |
Junior Member |
Quote:Just to be sure we're completely on the same "page". Firstly, I assume you are referring to the preference Editors -> Text Editors -> Displayed tab width, correct?
Yes, correct. I don't want to limit just to that setting only. Should be any setting in Eclipse preference. But of course we can make thing simple that just get that one as an example.
Quote:Do project A and project B have associated Oomph setups?
Currently no. All the rule/convention is in plain text.
Ex:
+ Tab indent is space and 4.
+ Print margin is 120
Quote:I ask that because of course a project setup can set this preference; but I think I was wrong earlier, i.e., I think that the user setup's preference task will override the one in the project even if the project has a task for that preference. I also ask because in general, via the "Show Advanced Properties" filter in the properties view, every task has a Restrictions reference that can be used to restrict that task to perform only when that scope is present, so it's possible to define a preference that applies only for project A or project B assuming those have setups defined...
Oh, that sounds like a solution. Sorry for my inexperience, how do you have a "project setup" to set that preference?
[Updated on: Sun, 25 October 2020 09:49] Report message to a moderator
FUDForum. Page generated in 0.04456 seconds
