Searching for Help in replacing actionSet with Commands/Menu [message #1833428] |
Mon, 12 October 2020 22:41 |
Peter Dell Messages: 12 Registered: September 2011 |
Junior Member |
My WUDSN-IDE Eclipe plugin started 10 years ago and has been upgraded along with all eclipse version ever since. It all still works fine, but I'd really like to replace the usages of the depreacted actions/actionSet which are still used for creating a dynamic toolbar menu,
The code is available on github:
https://github.com/peterdell/wudsn-ide
The warnings that I get are
Element 'action' is deprecated plugin.xml /com.wudsn.ide.asm line 327 Plug-in Problem
Element 'action' is deprecated plugin.xml /com.wudsn.ide.asm line 382 Plug-in Problem
Element 'action' is deprecated plugin.xml /com.wudsn.ide.asm line 389 Plug-in Problem
Element 'actionSet' is deprecated plugin.xml /com.wudsn.ide.asm line 323 Plug-in Problem
Element 'viewerContribution' is deprecated plugin.xml /com.wudsn.ide.asm line 379 Plug-in Problem
The extension point 'org.eclipse.ui.actionSets' is deprecated plugin.xml /com.wudsn.ide.asm line 322 Plug-in Problem
The extension point 'org.eclipse.ui.popupMenus' is deprecated plugin.xml /com.wudsn.ide.asm line 378 Plug-in Problem´
I've managed to use commands in most places, but I fail to find examples on how to correctly fix the above cases.
And pointers would be hightly appreciated.
Best regards, Peter/JAC!
FUDForum. Page generated in 0.04814 seconds
