Home » Eclipse Projects » Mosquitto » Project not reconnecting(Not auto reconnecting)
Project not reconnecting [message #1831889] |
Tue, 01 September 2020 20:48 |
Hello All,
I have a SCD-30 CO2 sensor a Miflora plant sensor a DS18B20 and a SSR-40A-relay.
All connected to my mosquitto.
The SCD-30 and the Miflora plant sensors are reconnecting when the connection is lost.
The Relay and DS18B20 are nor reconnecting.
I think the problem is within mosquitto, but i need to be sure of this.
I do see in the serial monitor "Reconnecting" every 5 seconds, when the connection has been lost.
I use the same mosquitto user for al my sensors.
This is my code for the DS18B20.
#include <OneWire.h>
#include <DallasTemperature.h>
#include <WiFi.h>
#include <PubSubClient.h>
//Wifi Settings
const char* ssid = "MySSID";
const char* password = "MyPass";
//MQTT Settings
const char* mqttServer = "IP";
const int mqttPort = 1883;
const char* mqttUser = "USer";
const char* mqttPassword = "Passwd";
WiFiClient espClient;
PubSubClient client(espClient);
int period = 5000;
unsigned long time_now = 0;
long lastReconnectAttempt = 0;
uint64_t chipid = ESP.getEfuseMac(); // MAC address of ESP32
uint16_t chip = (uint16_t)(chipid >> 32);
char clientid[25];
boolean reconnect() {
if (client.connect(clientid, mqttUser, mqttPassword )) {
// Once connected, publish an announcement...
client.publish("DS18B20/Info", "Reconnected", true);
return client.connected();
// GPIO where the DS18B20 is connected to
const int oneWireBus = 4;
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(oneWireBus);
// Pass our oneWire reference to Dallas Temperature sensor
DallasTemperature sensors(&oneWire);
void setup() {
// Start the Serial Monitor
Serial.begin(115200);
// Start the DS18B20 sensor
sensors.begin();
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.println("Connecting to WiFi..");
Serial.println("Connected to the WiFi network");
snprintf(clientid, 25, "ESP32-%08X", chip);
client.setServer(mqttServer, mqttPort);
while (!client.connected()) {
Serial.println("Connecting to MQTT...");
Serial.println("connected");
} else {
Serial.print("failed with state ");
Serial.print(client.state());
delay(2000);
void loop() {
time_now = millis();
sensors.requestTemperatures();
float temperatureC = sensors.getTempCByIndex(0);
if (!client.connected()) {
unsigned long now = millis();
if (now - lastReconnectAttempt > 5000UL) {
lastReconnectAttempt = now;
// Attempt to reconnect
Serial.print("Reconnecting");
if (reconnect()) {
} else {
// Client connected
while (millis() < time_now + period) {
//wait approx. [period] ms
Serial.print(temperatureC);
Serial.println("ºC");
client.publish("DS18B20/Temp", String(temperatureC, 2).c_str());
client.loop();
This is my relay code:
#include <WiFi.h>
//Wifi Settings
//MQTT Settings
uint16_t chip = (uint16_t)(chipid>>32);
char clientid[25];
client.publish("relay/Info","Reconnected", true);
void setup() {
pinMode(4, OUTPUT);
delay(500);
snprintf(clientid,25,"ESP32-%08X",chip);
client.setCallback(callback);
} else {
delay(2000);
client.subscribe("relay");
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived in topic: ");
Serial.println(topic);
Serial.print("Message:");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
Serial.println();
Serial.println("-----------------------");
if (payload[0] == '1') {
digitalWrite(4, HIGH);
else if (payload[0] == '0') {
digitalWrite(4, LOW);
Serial.println(digitalRead(4) ? "HIGH" : "LOW"); // <<<<<<< NEW
void loop(){
client.publish("relay/Info1","Reconnecting", true);
if (reconnect()) {
} else {
// Client connected
client.loop();
This is my mosquitto log:
1598871070: Socket error on client ESP12-00313D81, disconnecting.
1598871070: New connection from 192.168.178.227 on port 1883.
1598871070: New client connected from 192.168.178.227 as ESP12-00313D81 (p2, c1, k15, u'openhab').
1598871070: No will message specified.
1598871070: Sending CONNACK to ESP12-00313D81 (0, 0)
1598871074: Socket error on client ESP12-00313D81, disconnecting.
1598871074: New connection from 192.168.178.227 on port 1883.
1598871074: New client connected from 192.168.178.227 as ESP12-00313D81 (p2, c1, k15, u'openhab').
1598871074: No will message specified.
1598871074: Sending CONNACK to ESP12-00313D81 (0, 0)
1598871075: New connection from 192.168.178.206 on port 1883.
1598871075: Client miflora-client already connected, closing old connection.
1598871075: New client connected from 192.168.178.206 as miflora-client (p2, c1, k15, u'openhab2').
1598871075: No will message specified.
1598871075: Sending CONNACK to miflora-client (0, 0)
1598871077: New connection from 192.168.178.227 on port 1883.
1598871077: Client ESP12-00313D81 already connected, closing old connection.
1598871077: New client connected from 192.168.178.227 as ESP12-00313D81 (p2, c1, k15, u'openhab').
1598871077: No will message specified.
1598871077: Sending CONNACK to ESP12-00313D81 (0, 0)
Greetings.
Current Time: Fri May 03 00:06:39 GMT 2024
Powered by FUDForum. Page generated in 0.03207 seconds
