Re: Diagnosing update issue [message #1830034 is a reply to message #1830014] |
Thu, 16 July 2020 04:55 |
Ed Merks Messages: 33145 Registered: July 2009 |
Yes, this sounds complicated and it sounds like you've already done a bunch of digging in the proper places. I would generally expect p2 to find the/a solution that really does updates if such a solution exists (is possible); after all that's what I generally see it doing. I wonder if something in org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.adjustProfileChangeRequest(IProfileChangeRequest, IProgressMonitor) might be creating a requirement with a range that excludes possibility to update. The logic here merges the requirements on what's already installed with the requirements specified in the p2 task...
Ed Merks
FUDForum. Page generated in 5.03969 seconds
