Issue opening eclipse+installer URL on Kubuntu [message #1829796] |
Fri, 10 July 2020 15:43 |
Lutz Wrage Messages: 181 Registered: July 2009 |
I'm not sure if this is an issue with Oomph, general Eclipse, KDE, or something else:
I am running the eclipse installer on Kubuntu. It has created a *.desktop file to register the "eclipse+installer" protocol handler, which is set to run eclipse-inst %u , where %u stands for the URL.
When I click on the Launch... link on https://www.eclipse.org/setups/installer/?url=https://git.eclipse.org/c/justj/justj.tools.git/plain/releng/org.eclipse.justj.tools.releng/JustJConfiguration.setup&show=true I get a dialog to select the application (Eclipse Installer is pre-selected), and when I confirm nothing happens.
Same when I run
eclipse-inst eclipse+installer:https://git.eclipse.org/c/justj/justj.tools.git/plain/releng/org.eclipse.justj.tools.releng/JustJConfiguration.setup
from the command line.
However, when I add an additional argument (e.g., "-consoleLog", or even just a "-") before the URL the eclipse installer starts and applies the configuration from the URL as expected:
Working command line:
eclipse-inst - eclipse+installer:https://git.eclipse.org/c/justj/justj.tools.git/plain/releng/org.eclipse.justj.tools.releng/JustJConfiguration.setup
Opening "eclipse+installer" links works if I apply this fix to the .desktop file.
Does anybody have an idea what may be going on?
FUDForum. Page generated in 0.03830 seconds
