CompleteOCL - Import URI [message #1826160] |
Mon, 20 April 2020 13:59 |
Test Test Messages: 3 Registered: April 2020 |
Junior Member |
Running eclipse Modeling Tools
Version: 2020-03 (4.15.0)
Build id: 20200313-1211
with eclipse OCL 6.11.0
The current project is currently set as an OCL project and I created an .ocl - File with some basic invariants in it. When I want to import the meta model from my local files it can resolve, because the meta model is also in the project.
import basic : 'platform:/plugin/org.gravity.typegraph.basic/model/Basic.ecore'
But I want to import the meta model from an URI, as it doesn't resolve when I use the exact path name which is:
import ecore : 'http://www.eclipse.org/emf/2002/Ecore#/'
import basic : 'http://www.gravity-tool.org/typegraph/basic#/'
package basic
context TClass
inv Test : false
endpackage
where is the issue? Did I forget to configure anything or is the syntax of the imported URI incorrect?
[Updated on: Thu, 23 April 2020 08:06] Report message to a moderator
FUDForum. Page generated in 0.03483 seconds
