WindowBuilder encountered unexpected internal error. [message #1823311] |
Tue, 24 March 2020 17:24 |
firos meethal Messages: 1 Registered: March 2020 |
Junior Member |
Internal Error
This could be caused by a WindowBuilder bug or by a misconfiguration issue, conflict, partialupdate, etc.
java.lang.Error: Unable to open file /resources/1.8/org/eclipse/wb/swing/FocusTraversalOnArray.java from org.eclipse.wb.swing
Hide stack trace.
Stack trace:
at org.eclipse.wb.internal.core.BundleResourceProvider$3.runObject(BundleResourceProvider.java:145)
at org.eclipse.wb.internal.core.BundleResourceProvider$3.runObject(BundleResourceProvider.java:1)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runObject(ExecutionUtils.java:275)
at org.eclipse.wb.internal.core.BundleResourceProvider.getFile0(BundleResourceProvider.java:143)
at org.eclipse.wb.internal.core.BundleResourceProvider.getFile(BundleResourceProvider.java:139)
at org.eclipse.wb.internal.core.BundleResourceProvider$2.runObject(BundleResourceProvider.java:128)
at org.eclipse.wb.internal.core.BundleResourceProvider$2.runObject(BundleResourceProvider.java:1)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runObject(ExecutionUtils.java:246)
at org.eclipse.wb.internal.core.BundleResourceProvider.getFileString(BundleResourceProvider.java:126)
at org.eclipse.wb.internal.core.utils.jdt.core.ProjectUtils.ensureResourceType(ProjectUtils.java:180)
at org.eclipse.wb.internal.swing.model.property.TabOrderProperty.setOrderedArraySource(TabOrderProperty.java:93)
at org.eclipse.wb.internal.core.model.property.order.TabOrderProperty.setValueEx(TabOrderProperty.java:159)
at org.eclipse.wb.internal.core.model.property.order.TabOrderProperty.access$1(TabOrderProperty.java:140)
at org.eclipse.wb.internal.core.model.property.order.TabOrderProperty$2.run(TabOrderProperty.java:135)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.run(ExecutionUtils.java:324)
at org.eclipse.wb.internal.core.model.property.order.TabOrderProperty.setValue(TabOrderProperty.java:133)
at org.eclipse.wb.internal.core.model.property.order.TabOrderPropertyEditor.openDialog(TabOrderPropertyEditor.java:58)
at org.eclipse.wb.internal.core.model.property.editor.TextDialogPropertyEditor$1.onClick(TextDialogPropertyEditor.java:35)
at org.eclipse.wb.internal.core.model.property.editor.presentation.ButtonPropertyEditorPresentationImpl$4.handleEvent(ButtonPropertyEditorPresentationImpl.java:124)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4175)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3988)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3587)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1160)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1049)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:660)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:559)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Full context stack trace:
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runObject(ExecutionUtils.java:278)
Caused by: java.lang.NullPointerException
... 42 more
FUDForum. Page generated in 0.02889 seconds
