Java11 e4 application openjfx [message #1819395] |
Tue, 14 January 2020 14:39 |
Nico Beckers Messages: 15 Registered: January 2020 |
Junior Member |
Hello everybody,
I am having some trouble getting an e4 application, together with openjfx and java11 (AdoptOpenJDK) to run.
The content of my target file looks like this:
<locations>
<location includeAllPlatforms="false" includeConfigurePhase="true" includeMode="planner" includeSource="true" type="InstallableUnit">
<repository location="http://download.eclipse.org/efxclipse/runtime-released/3.5.0/site/"/>
<unit id="org.eclipse.fx.core.feature.feature.group" version="3.5.0.201902252257"/>
<unit id="org.eclipse.fx.slf4j.target.feature.feature.group" version="3.5.0.201902250700"/>
<unit id="org.eclipse.fx.target.feature.feature.group" version="3.5.0.201902252257"/>
</location>
<repository location="http://download.eclipse.org/eclipse/updates/4.9"/>
<unit id="org.eclipse.platform.sdk" version="4.9.0.I20180906-0745"/>
</location>
<repository location="http://downloads.efxclipse.bestsolution.at/p2-repos/openjfx-11/repository/"/>
<unit id="openjfx.media.feature.feature.group" version="11.0.0.201901231300"/>
<unit id="openjfx.standard.feature.feature.group" version="11.0.0.201901231300"/>
<unit id="openjfx.swing.feature.feature.group" version="11.0.0.201901231300"/>
<unit id="openjfx.swt.feature.feature.group" version="11.0.0.201901231300"/>
<unit id="openjfx.web.feature.feature.group" version="11.0.0.201901231300"/>
</location>
</locations>
but unless I add " --module-path <local-path>\javafx-sdk-11.0.2\lib --add-modules javafx.graphics,javafx.controls,javafx.fxml", I always get the following error when running (note: the projects compiles fine with this target):
!SESSION 2020-01-14 15:26:49.990 -----------------------------------------------
eclipse.buildId=unknown
java.version=11.0.5
java.vendor=AdoptOpenJDK
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product <shortened>.application.product
Command-line arguments: -product <shortened>.application.product -data <shortened>.app.product.product -dev file:<shortened>/.metadata/.plugins/org.eclipse.pde.core/<shortened>.app.product.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog -data @user.home/ws
!ENTRY org.eclipse.equinox.app 4 0 2020-01-14 15:26:52.996
!MESSAGE javafx/application/Application
!STACK 0
java.lang.NoClassDefFoundError: javafx/application/Application
at java.base/java.lang.ClassLoader.defineClass1(Native Method)
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1016)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:279)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:703)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:626)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:594)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:574)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:553)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:331)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:414)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:153)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
at org.eclipse.fx.ui.workbench.fx.E4Application.getJfxApplicationClass(E4Application.java:396)
at org.eclipse.fx.ui.workbench.fx.E4Application.launchE4JavaFxApplication(E4Application.java:381)
at org.eclipse.fx.ui.workbench.fx.E4Application.start(E4Application.java:179)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:199)
at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:29)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: java.lang.ClassNotFoundException: javafx.application.Application cannot be found by org.eclipse.fx.ui.workbench.fx_3.5.0.201902252257
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:511)
... 21 more
Does anyone know what is missing in order to get this to run?
Best regards.
[Updated on: Fri, 17 January 2020 12:02] Report message to a moderator
FUDForum. Page generated in 0.02994 seconds
