Re: Unable to install LDT to Eclipse 2019-12 (4.14.0) [message #1819304 is a reply to message #1819264] |
Sun, 12 January 2020 22:13 |
Dave Alkire Messages: 1 Registered: January 2020 |
Junior Member |
My own issue was similar enough that maybe my solution can work for you.
My scene:
I tried to install from Install New Software from site "http://download.eclipse.org/ldt/releases/stable" though I also had the other LDT sites enabled, same URL but ending in "/milestones" and "/updates-nightly"; I'm not sure if having those made a difference but anyway my errors were like:
"No repository found containing: osgi.bundle,org.eclipse.dltk.core,5.7.1.201703020501"
...plus 5 others, same except instead of "core" they were "debug", "debug.ui", "formatter", "launching" and "ui".
My solution was basically to provide the missing resource from a download since it doesn't seem to be available from repositories any more:
Download the runtime for DLTK 5.7.1 as a zip: Here's a direct link and its MD5. Save it to some logical place; I chose my root eclipse install directory but whatever.
In Eclipse, navigate to menu > Help > Install new software...
Click Manage... to go to Available Software Sites dialog
Click Add... use a good name like "LDTK zip", click the "Archive" button and browse to that zip, downloaded from before.
Then when I tried again the install happened correctly and my initial tests indicate that LDT is working as expected.
Re: Unable to install LDT to Eclipse 2019-12 (4.14.0) [message #1841692 is a reply to message #1819030] |
Tue, 25 May 2021 19:03 |
Dan Delgado Messages: 4 Registered: January 2020 |
Junior Member |
This is AWESOME news!
I have not tried it - at work atm (different environ), but based on replies I am hopeful.
I was installing a new Eclipse for Java on my temp laptop for work prior to sending the other for service and setting that up to be able to build made me think of my old Lua issue.
I was about to post again asking if anyone knew of any LUA solution for Eclipse if there had been a replacement plugin in intervening years. Great news again - can't wait to try later today.
EDIT: ==> Successfully installed, thank you - tomorrow I play with it again.
[Updated on: Wed, 26 May 2021 03:02] Report message to a moderator
FUDForum. Page generated in 0.03937 seconds
