Re: Is it permitted to publish in message callback? [message #1815766 is a reply to message #1815731] |
Thu, 10 October 2019 07:47 |
Liam Fry Messages: 3 Registered: October 2019 |
Junior Member |
As it turns out, yes, you can publish while inside the message handler.
After much trial and error, I found a solution but not the cause.
The solution: I had to raise my QoS from 0 to 1 on both publish and subscribe. If I don't raise the QoS, in my situation, I found that 97.2% of all "published while in message handler" messages were never delivered. Once QoS was raised to 1, delivery rate reached 100%. Unfortunately, raising the QoS to 1 has added an average of 800ms to message delivery time with approximately 12% of publications taking up to 3 seconds to be delivered.
UPDATE: I failed to note in my original post: all components - broker and my clients - are running on the same host. These times are stunningly bad and it does not bode well for when my application is released to the network.
I think it's worth noting that, when I alter my application in such a way as to move publications outside the message handler, delivery rate is fast and 100%, even with QoS at 0. Unfortunately, re-working my application so that no publications ever occur from within the message handler breaks functionality for which there is no easy solution at this time.
FUDForum. Page generated in 0.03266 seconds
