Re: Adding Numerical Methods (LNA) To the Project [message #1815220 is a reply to message #1815204] |
Fri, 27 September 2019 11:57 |
Saeed Ghofrani Jahromi Messages: 33 Registered: September 2019 |
Member |
In The Name OF GOD,
The Source Code Of CPLua Project is attached .
It may be used to make the Broyden Method And the Ghofrani Method To Solve the System Of Nonlinear Equations in LDT Project .
It is something like vector Input for functions that is used in Broyden Method And Ghofrani Method to Solve the Nonlinear System Of Equations .
Broyden Method And Ghofrani Method can be run in this way :
1. Run Cplua.exe (Downloadable From the Reply 2 to the Post)
2. Right Click on the Cplua Screen and open the LNA (Lua Numerical Methods) Library
3. Open the Folder LNAexamp Folder And Open XGhof.lua Or XBroyden.lua file and then run.
[Updated on: Fri, 27 September 2019 11:57] Report message to a moderator
FUDForum. Page generated in 0.04164 seconds
