RCPTT is not working with 201906 platform [message #1809949] |
Fri, 26 July 2019 07:57 |
Hello
I am trying to use RCPTT installed in a 201906 developpement environment to test a eclipse product based on 201906 platform.
I encountered two kinds of problems
My installation:
* From a "Eclipse IDE for Eclipse Committers" 201906
* I installed RCPTT 2.4.2 from the update site https://download.eclipse.org/rcptt/release/2.4.2/repository
First issue:
* I have a launch config that starts an eclipse based on 201906 Target Platform
* When starting the EAUT I get the following message in a dialog box:
Title:AUT Connection Error
Message : Invalid eclipse target platform: New_configuration with RCPTT
Second issue:
* I created a new AUT referencing a product based on eclipse oxygen to check that the issue was related to testing a 201906 AUT
* When launching the EAUT, it starts correctly but I keep having the Progress monitor in the eclipse where I started the EAUT and it is stuck with the message "Starting virtual machine"
Then I can't start my RCPTT suite.
Note that if I start directly my RCPTT suite which starts the EAUT, the suite is not started neither.
Questions:
* Any hint? workaround? ;)
* Otherwise I feel that that the 2.4.2 version is not suitable for 201906 platform. Is it the case? Is the targeted 2.5.0 version suitable? But is the 2.5.0 nightly version stable enough to be use as of now?
Thank you for your answer?
Laurent
[Updated on: Fri, 26 July 2019 07:59] Report message to a moderator
FUDForum. Page generated in 0.02894 seconds
