Re: Is the kura cloud communication to kapua secured with TLS? [message #1808675 is a reply to message #1808122] |
Fri, 28 June 2019 13:12 |
Aistis Kaikaris Messages: 33 Registered: March 2018 |
Member |
Since the kapua forum seems to be a bit dead (did not get a response), i figured i would host my own broker with tls and see if the kura gateways would connect to it. Alas i'm now getting other errors with no successful connection. This is what i did.
1) Created a broker private key m2mqtt_srv.key
2) Created a broker certificate m2mqtt_srv.crt
3) Created a self signed CA certificate m2mqtt_ca.crt
4) Hosted a mosquitto mqtt broker on port 8883 with the tlsv1.0, tlsv1.1, tls1.2 enabled and the previously created certificates and keys.
5) I tested out the mosquitto broker secure connection with this command:
mosquitto_pub -h 192.168.125.110 -t test/device --cafile m2mqtt_ca.crt -m "hello" -p 8883
It worked and the message was published.
6) In kura device ui i went to the Settings -> Server SSL Certificate tab
a) In "Storage Alias" field i wrote in my name from the "Topic Context Account-Name" field
b) In the "Certificate" field i pasted my self signed certificate m2mqtt_ca.crt:
-----BEGIN CERTIFICATE-----
MIIEBTCCAu2gAwIBAgIUc2g7zOgAD9/Dd/78YJPFDXvxxaswDQYJKoZIhvcNAQEL
BQAwgZExCzAJBgNVBAYTAkxUMREwDwYDVQQIDAhLbGFpcGVkYTERMA8GA1UEBwwI
S2xhaXBlZGExDjAMBgNVBAoMBUlhbXVzMRIwEAYDVQQLDAlJYW11cyBkZXYxGDAW
BgNVBAMMDzE5Mi4xNjguMTI1LjExMDEeMBwGCSqGSIb3DQEJARYPaWFtdXNAaWFt
uSZ6onL5TjThSRYdOiY6s4cAg11gk6x3McLkDPRZCtemHzJKs3I5Yb/+b2rYdHrn
49W6/jx2mN/xd/s5WiR2vxcCbWZ0IRZKTLRakPDMueqyVTxi8cb1o6ujOMI5xTfU
lKZeJbObAlBZ0Z7ai43f9mIm6IzqL4L3sQ==
-----END CERTIFICATE-----
c) Clicked "apply"
7) Tried to connect to the mosquitto broker with the kura gateway and got an error:
2019-06-28T11:43:07,960 [qtp1096499602-108] WARN o.e.k.w.s.GwtNetworkServiceImpl - Error connecting
org.eclipse.kura.KuraConnectException: "Connection failed. Cannot connect"
at org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport.connect(MqttDataTransport.java:337)
at org.eclipse.kura.core.data.DataServiceImpl.connect(DataServiceImpl.java:489)
at org.eclipse.kura.web.server.GwtStatusServiceImpl.connectDataService(GwtStatusServiceImpl.java:103)
at com.google.gwt.user.server.rpc.RPC.invokeAndEncodeResponse(RPC.java:587)
at com.google.gwt.user.server.rpc.RemoteServiceServlet.processCall(RemoteServiceServlet.java:333)
at com.google.gwt.user.server.rpc.RemoteServiceServlet.processCall(RemoteServiceServlet.java:303)
at com.google.gwt.user.server.rpc.RemoteServiceServlet.processPost(RemoteServiceServlet.java:373)
at com.google.gwt.user.server.rpc.AbstractRemoteServiceServlet.doPost(AbstractRemoteServiceServlet.java:62)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.eclipse.kura.web.server.OsgiRemoteServiceServlet.service(OsgiRemoteServiceServlet.java:41)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl$LegacyServlet.service(HttpServiceRuntimeImpl.java:1223)
at org.eclipse.equinox.http.servlet.internal.registration.EndpointRegistration.service(EndpointRegistration.java:148)
at org.eclipse.equinox.http.servlet.internal.servlet.ResponseStateHandler.processRequest(ResponseStateHandler.java:62)
at org.eclipse.equinox.http.servlet.internal.context.DispatchTargets.doDispatch(DispatchTargets.java:131)
at org.eclipse.equinox.http.servlet.internal.servlet.ProxyServlet.service(ProxyServlet.java:74)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:284)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1340)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1242)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.Server.handle(Server.java:503)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:364)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:765)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:683)
at java.lang.Thread.run(Thread.java:748)
Caused by: MqttException (0) - javax.net.ssl.SSLHandshakeException: java.security.cert.CertificateException: No subject alternative names present
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:38)
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:736)
... 1 more
Caused by: javax.net.ssl.SSLHandshakeException: java.security.cert.CertificateException: No subject alternative names present
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1946)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:316)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1639)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:223)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:965)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379)
at org.eclipse.paho.client.mqttv3.internal.SSLNetworkModule.start(SSLNetworkModule.java:149)
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:722)
... 1 more
Caused by: java.security.cert.CertificateException: No subject alternative names present
at sun.security.util.HostnameChecker.matchIP(HostnameChecker.java:145)
at sun.security.util.HostnameChecker.match(HostnameChecker.java:94)
at sun.security.ssl.X509TrustManagerImpl.checkIdentity(X509TrustManagerImpl.java:455)
at sun.security.ssl.X509TrustManagerImpl.checkIdentity(X509TrustManagerImpl.java:436)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:200)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1621)
... 10 more
8) I tried the above on 3 different kura devices, 2 docker container and one natively installed (all of them at version 4.1.0)
9) Then i tried to host a openssl server to check what is going on with the handshake:
openssl s_server -accept 8883 -cert m2mqtt_srv.crt -key m2mqtt_srv.key -verify 10 -CAfile m2mqtt_ca.crt
10) I first tried to again test with the mosquitto publisher:
mosquitto_pub -h 192.168.125.110 -t kiosks/device --cafile m2mqtt_ca.crt -m "hello" -p 8883
and in the openssl server i get:
-----BEGIN SSL SESSION PARAMETERS-----
MFoCAQECAgMDBALAMAQABDDvZ4d/rpld8bGXum1pAJLfTsjXKmcp+3eIo62xoNwp
xeVIDbidTL0/qI015m3i7VmhBgIEXRYQd6IEAgIcIKQGBAQBAAAArQMCAQE=
-----END SSL SESSION PARAMETERS-----
Shared ciphers:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:DHE-RSA-AES256-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES256-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:DHE-RSA-AES128-SHA:AES256-GCM-SHA384:AES128-GCM-SHA256:AES256-SHA256:AES128-SHA256:AES256-SHA:AES128-SHA
Signature Algorithms: ECDSA+SHA256:ECDSA+SHA384:ECDSA+SHA512:Ed25519:Ed448:RSA-PSS+SHA256:RSA-PSS+SHA384:RSA-PSS+SHA512:RSA-PSS+SHA256:RSA-PSS+SHA384:RSA-PSS+SHA512:RSA+SHA256:RSA+SHA384:RSA+SHA512:ECDSA+SHA224:ECDSA+SHA1:RSA+SHA224:RSA+SHA1:DSA+SHA224:DSA+SHA1:DSA+SHA256:DSA+SHA384:DSA+SHA512
Shared Signature Algorithms: ECDSA+SHA256:ECDSA+SHA384:ECDSA+SHA512:Ed25519:Ed448:RSA-PSS+SHA256:RSA-PSS+SHA384:RSA-PSS+SHA512:RSA-PSS+SHA256:RSA-PSS+SHA384:RSA-PSS+SHA512:RSA+SHA256:RSA+SHA384:RSA+SHA512:ECDSA+SHA224:ECDSA+SHA1:RSA+SHA224:RSA+SHA1:DSA+SHA224:DSA+SHA1:DSA+SHA256:DSA+SHA384:DSA+SHA512
Supported Elliptic Curve Point Formats: uncompressed:ansiX962_compressed_prime:ansiX962_compressed_char2
Supported Elliptic Groups: X25519:P-256:X448:P-521:P-384
Shared Elliptic groups: X25519:P-256:X448:P-521:P-384
No server certificate CA names sent
CIPHER is ECDHE-RSA-AES256-GCM-SHA384
Secure Renegotiation IS supported
11) I then try the same with the kura gateway and in the openssl server i get:
ERROR
139965834281408:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../ssl/record/rec_layer_s3.c:1528:SSL alert number 46
shutting down SSL
CONNECTION CLOSED
12) Both the mosquitto publisher and the kura gateway use the same CA certificate
I'm currently running out of ideas as to what might be wrong with my setup. Can anyone spot any errors that i made?
[Updated on: Fri, 28 June 2019 13:13] Report message to a moderator
FUDForum. Page generated in 0.04948 seconds
