Re: Kura eclipse emulator and DS activation problems [message #1803336 is a reply to message #1803237] |
Wed, 27 February 2019 05:54 |
Aistis Kaikaris Messages: 33 Registered: March 2018 |
Member |
Ok, so it seems when you pass an int argument to the deactivator method, it tells you about the reason the service/component was deactivated:
0 - unspecified
1 - The component was disabled
2 - A reference became unsatisfied
3 - A configuration was changed
4 - A configuration was deleted
5 - The component was disposed
I figured out that one of the services was a configurable component and it's being modified, so all it's clients get restarted as well. For the other one i'm getting "0", so the problem is unspecified.
The dynamic reference bind problem disappeared when i changed the class from service to a simple component. Not sure why that would do anything, since on further inspection the service was not being used by anyone, but at least that seems to help.
[Updated on: Wed, 27 February 2019 05:59] Report message to a moderator
FUDForum. Page generated in 0.03030 seconds
