How to create customized kura components and use them in Wire graph [message #1801114] |
Mon, 14 January 2019 08:40 |
Khaled Alanezi Messages: 3 Registered: January 2019 |
Junior Member |
I just learning in able to be able to use Kura in my project and I'm unable to connect the dots here. So, I followed the hello world example [1] and was able to see log messages getting printed inside eclipse using the OSGi Framework-Kura_Emulator_OSX . After that, I wanted to start using Kura wires to develop my solution, so, I'm following the How to use DB Store and Filter components in Kura Wires tutorial here [2]. I completed the graph (without the cloud part for simplicity) and clicked Apply . The wires are now blinking which indicates that the data (envelopes) are moving between my 3 connected components (timer -> opcua-driver -> logger). Now, how do I deploy this application that I created using Kura Wires? how to see its output?
Note : I checked my [b] /var/log/ [\b] folder and I don't see neither the kura.log file nor kura-console.log files.
[1]http://eclipse.github.io/kura/dev/hello-example.html
[2]http://eclipse.github.io/kura/wires/kura-wires-dbfilter.html
[Updated on: Tue, 15 January 2019 07:44] Report message to a moderator
FUDForum. Page generated in 0.03783 seconds
