Home » Eclipse Projects » Eclipse Platform » Eclipse 3.3.2 - compiling workspace takes an extremely long time.
Eclipse 3.3.2 - compiling workspace takes an extremely long time. [message #335109] Mon, 23 March 2009 10:15 Go to next message
Good morning,
I am running into the problem where the recompilation of the workspace
(Dynamic web project) is taking an extremely long time.
I have run into the problem in the past and seemed to be solved by going to
a clean Eclipse image, but it is occurring again.
I kind of get the feeling that it is related to some combination of plugins
that I have but have no clue how to track it down.
Is this a known problem or has anyone else run across this.
Thanks in advance.
Whatty
Re: Eclipse 3.3.2 - compiling workspace takes an extremely long time. [message #335118 is a reply to message #335109] Mon, 23 March 2009 12:37 Go to previous messageGo to next message
"Whatty" <steven.whatmore@lynxdev.com> wrote in message
news:gq85i1$9tr$1@build.eclipse.org...
> Good morning,
> to a clean Eclipse image, but it is occurring again.
> plugins that I have but have no clue how to track it down.
One thing you can do is run Eclipse with eclipsec.exe rather than
eclipse.exe; that will give you a console window. Then, while it's in a
slow build, you can hit Ctrl+Break and that should give you a thread dump.
Do a couple of thread dumps and you may be able to get a sense of what part
of the code is taking so long.
Dynamic web projects can be slowed by a number of things. One is schema
validation, if it has to go out on the network to find a schema. Also if
there are large jar files on the classpath, it can exceed cache limits and
start thrashing in some cases.
Re: Eclipse 3.3.2 - compiling workspace takes an extremely long time. [message #335138 is a reply to message #335118] Tue, 24 March 2009 02:13 Go to previous message
In the past, I've experienced a very slow build due to a schema
validation. Also if you have other facets, they might also consume a good
amount of time (like Cypal Studio for GWT, which triggers GWT Compiler
during a build)
- Prakash
http://blog.eclipse-tips.com
Previous Topic:Synchronous reorder of columns in two tables
Next Topic:Restoring toolbar item state of last session
Current Time: Sat Nov 08 01:24:31 EST 2025
Powered by FUDForum. Page generated in 0.03506 seconds
